400A
- May 26, 2003
Note to Self: Never get in an airplane with Captain Stick Shaker.
Got that right!!! But instead, others who would not do it were terminated.
Actually, DP Climb Gradients are based upon "all engine" operations. Period, end of discussion. The takeoff performance charts in Part 25 transport category business jets only gets you to to 1500' AGL - in other words, pattern altitude. At that point you either come back around and land or you need to have the performance to do something else. This is a "corporate" forum so I'm assuming we're talking Part 91 operations here. Under part 91, you have no obligation to be able to achieve the required climb gradients after the loss of an engine; however, common sense and professionalism requires that you have a plan B just in case... This is where the "alternate" departure procedures come into play for 121, 135, and savy 91 operators. Oh well, this will probably start another firestorm. I recommend doing a search on Aspen. We've plowed this ground many times before....clearly not understanding that the performance numbers are based on single engine performance.
That's even better. From what he was saying I didn't get the impression that he was going for that much detail.UltraNav doesn't account for close-in obstacles. Can you say airport analysis?
That's not quite correct. You really can't extrapolate those charts - there are configuration, bank angle and speed constraints that make would make them inaccurate. The takeoff performance charts are good to 1500' AGL. I've had folks (even some factory demo pilots) try and give the same explaination - it just doesn't fly. The real answer is airport analysis, it's too bad that many pilots aren't aware of this.By the way, You can run the numbers for a gradient at any altitude. Simply back down 1500 feet in the charts.
Unfortunately, there are plenty of cowboys out there.I don't know how many times I've been told by a newbie that the charts aren't correct or that we shouldn't be doing something even though the charts say it will work. I have found that most of the pilots I have dealt with are very conscientious about checking performance, and have met very few cowboys. I have heard lots of talk about "those guys" that are cowboys. I just haven't actually come across "those guys" in person.
