Have you checked performance #s?
Really? You'll have to explain that to me.
The chart doesn't know what altitude your departure airport is, so if you tell it that you need to maintain 800 ft/nm to 10,000 feet and you are able to achieve that from 8500 to 10,000...then it stands to reason that you would be able to achieve it at less than 8500. Right?
I'm not questioning you, just wondering if I correctly understand the second-segment climb tables. (Lear takes 2nd segment all the way to 1500)
As for airport analysis, I agree 100%. I used it for years in part 121 and our department recently started using it part 91. I feel much more comfortable with their calculations then with me ham-fisting the charts to get runway limit or climb limit.
There are several reasons you cannot use AFM 2nd segment climb data in meeting TERP's criteria. First, all the one engine-out climb flight path data (1st, 2nd, and final segment climb charts) are only good to 1,500 above the runway (however, some manufacturers have gone beyond this point up to 3,000 to 5,000 feet) and CANNOT be used to the heights demanded of certain DP's such as is the case of KASE, 7,800 ft to 14,000 ft. 2nd segment climb data is generally only valid to 400 ft above runway, the point where 2nd segment ends. Second, the differences in climb terminology. Most 2nd segment climb gradient charts in AFM's give the available NET climb gradient so that when you apply this to the flight path charts or computer program you get a resulting NET flight path. TERP's climb requirements are based on actual performance, NOT an already an already reduced NET climb gradient. Then there's the consideration of 5 minute limitation on takeoff thrust. Many DP's require climb gradients to significantly high altitudes that would exceed the limitation on takeoff thrust, not to mention a shallowing climb gradient due to density altitude changes as you climb. Remember if you try to use 2nd segment climb, you'll only meet that climb gradient if you keep V2, takeoff flaps, and takeoff thrust and that climb gradient is generally valid only at 400 ft above the runway. Additionally, the charts assume essentially "wings level" flight (I don't remember the exact bank angle limit and my files are at home.) and many DPs involve turns that would exceed these bank angle limitations.
Aircraft "1-engine out" part 25 certification requirements only get us to 1500' AGL on takeoff, after which we immediately transition into the enroute all-engine TERPS climb. I guess that the original intent was that if we could safely get up to pattern altitude after losing an engine on takeoff we could bring the airplane back around for a landing. The enroute climb phase is based on all engine operation. If an engine is lost during that phase, it is an emergency, justifying the use of "alternate departure procedures" as provided by folks like APG or Jeppesen. (The alternate procedure for ASE isn't all that limiting, but it's a pretty demanding procedure - one best practiced a time or two in the sim.)
LS
That makes perfect sense, thanks. So for those folks who do NOT have airport analysis and whose manufacturers do not provide all-engine climb data, how do they ensure they can comply with a TERPS climb gradient?
Oh well, that's easy - all you have to do is go to your flight manual and find the "All Engine Operating Enroute Climb Chart". Oh wait, they don't provide us with that information in the flight manual. Hmmm, I guess you essentially have to determine the required rate of climb based upon your climb speed (a table is provided on the DP chart) and using all of your skill and experience as a pilot to guesstimate if you will be able to achieve the required climb rate. (I don't have to stretch too much - as I remember, the DP at ASE only required a climb rate of about 1600 fpm at 14,000' MSL. The stuff I've been flying will normally do about twice that. ) I guess what I'm trying to say is that you really need to have an alternate procedure available to you in the event of an engine loss - just like the 121 guys have.
LS
Terps
Actually, it was a p135 mission. But good points nontheless.
Actually, DP Climb Gradients are based upon "all engine" operations. Period, end of discussion. The takeoff performance charts in Part 25 transport category business jets only gets you to to 1500' AGL - in other words, pattern altitude. At that point you either come back around and land or you need to have the performance to do something else. This is a "corporate" forum so I'm assuming we're talking Part 91 operations here. Under part 91, you have no obligation to be able to achieve the required climb gradients after the loss of an engine; however, common sense and professionalism requires that you have a plan B just in case... This is where the "alternate" departure procedures come into play for 121, 135, and savy 91 operators. Oh well, this will probably start another firestorm. I recommend doing a search on Aspen. We've plowed this ground many times before.
LS
Ultranav
KSU pilot may be able to produce this information for free, however in my opinion Ultranav is worth every penny and thensome.
I remember back in the Hawker charter days Ultranav giving me information within a minute to make determinations that would of taken 15 minutes or more if I pulled the Manuals out. Now if you have to do this once or twice yeah Ultranav seems a bit extravagent. But when you are flying charter on a daily basis and some of it includes high-altitude Colorado airports with constantly changing winds and other conditions it makes a heck of a lot more sense.
It's an extremely useful tool and quite honestly 1200 bucks isn't that much when you're dealing with million dollar airplanes.
I'd like to point out that airport analyses are company specific. You have to pay a vendor to develop the analysis for the specific airport and your airplane. I agree they're great, but the cost is prohibitive.
Ultra-Nav is great but it's only 1/2 of the correct solution. The real answer is to impliment both Ultra-Nav and airport analysis. Airport analysis will tell you how much you can carry and give you an alternate departure procedure if necessary and Ultra-Nav will quickly give you the numbers and speeds.
I'll have to disagree with Hugh Johnson, earlier this year I entered into an agreement with APG was for unlimited monthly usage for 1 airplane and the cost was less than $80 per month - hardly a cost prohibitive item.
LS
Very well stated. Some guys are over cautious to the safe side, and some throw the book right out the window.
I wish I had a dollar for every King Air 200 guy I have heard say "The Military operates them at 14,000 lbs" or what ever the actual number is.
Yes they do, but they have a type, 2 crew, and have trained in it at that weight...... you?
Other guys are always looking for a reason not to fly.
I know of one guy who regularly departs an airport with the stick shaker going off.
That's interesting...didn't know there was a stick shaker in a King Air 200.
Nope.
1. They don't have my aircraft.
2. I'm not spending $1200 to get information that I can produce for free!
I am glad you are not flying with me when you pull out the AFM, slide ruler and what ever else you need to get a number while your passengers and I wait. What do you do when conditions change at the last minute for example: it starts raining, they show up with extra passengers or runway change etc?
We use all available information, including Ultra-Nav.
Power to the people
We departed LFPB yesterday, and ATC asked us to keep the climb @ ta least 4k, so we gave them 5. After passing FL 150 about 3 min later we accelerated to 320 kts to make up for lost ground speed.
Like they say in the US of A, bigger is better.
Performance that is, and yes we do you use steroids, kerosene ;)
Nope.
Putting it in perspective. That $1200 is roughly 200 gal of fuel. If you don't think Ultra-Nav or EFBPro can save you that and more each year, you're in the wrong business and not doing all you can to reduce costs for the boss.
Huh???
Well said, howeever in his behalf, evidently Ultra-Nav doesn't have his airplane and you can't buy something from them that they don't have. However, there are other suppliers (EFBPro) that provide similar programs that would probably accomodate his airplane.
LJ was spot on, in the real world, no one pulls out the charts for day-to-day operations - at least as long as they have tab data that they can refer to and use. There's nothing wrong with that, but you need to understand the limitations of using tab data. For many of us this means that the only time they ever break out the charts is once or twice a year during the performance class during our recurrent training - hardly enough to stay proficient with the unwieldy and convoluted procedures involved.
That being said, you also need to understand the limitations of using programs live Ultra-Nav and EFBPro. Like I said in an earlier post on this thread, the real answer is airport analysis and a program like Ultra-Nav - APG will tell you what your weight limitations will be and provide you with alternate procedures if required. Ultra-Nav can then be used to quickly come up with the appropriate numbers.
LS
We use both Ultra-Nav and airport analysis from APG. The $1200 spent on Ultra-Nav and the $600 for APG is in my opinion worth every penny. Quick numbers from Ultra-Nav and alternate departure info for airports which allows us to take the extra fuel if needed and make it non-stop home. Also APG along with Ultra-Nav allows me from home to easily make the decision on which airport I can buy the most fuel at the best price.
That gives me more time to play with my kids and less time going cross-eyed looking at manuals.
Wow, you completely missed it. The point was that I could extrapolate all of the numbers on my own and not spend $1200 for something I could do for free. Nav or EFBPro only save me money if I'm spending money....I'M NOT SPENDING ANY MONEY!
I bet you bought a $30,000 Prius so that you could save $50 a month on gas.
Check out APG. They have most Corporate Aircraft and Roger Hemphill can give you a presentation that explains quite clearly what you can and cannot do. It also will enlighten you to close in obstacles and TORA, TODA, etc. By next year you will all be familiar with this as you will be required to have an LOA to close the loophole that has let us 91 guys launch without regard to obstacle clearance. Get APG even for airports that you wouldn't normally consider to be climb limited or hazardous (Like KAPF).
Ultra Nav is great. It's funny how much you can learn about your aircraft's performance from Ultra Nav. It's only about $1000 for unlimited licenses within your flight department. Again, if you are flying a jet and can't afford $1000 bucks for a safety tool like Ultra Nav, I just have to shake my head. Hell, get a bootleg copy and and see for yourself.
APG only costs $75.00 per AC per month. About the same cost as running your APU for 10 minutes.
Lead Sled has put forth some of the best information that I have seen on this board.
At the end of the day. A guy in a Caravan or Pilatus can take off out of Aspen with 1000 and 3 and a Guy in a Citation cannot. That is the FAA and Lawyers there to help you.
