Has US Airways started calling new applicants to interview?
Short call rsv in base , have flown 6 hours this month. Might not fly again in sep. Have been here a little less than a year , have flown with some of the nicest most laid back guys ive ever met. Other than horrendous pay life is not bad.
You live in base ? Airways pilots are most defn the most laid back. The old school 737 guys take the cake for sure
Come on Call !!! Call!!
Heard the application software is a bit of a mess right now. There are parameters set for applicants and then the calls go out "lottery style" to those that meet those set parameters.
Supposedly they are trying to fix this, but for now, that is the reason people with completely different sets of quals are getting calls.
How does reserve work? is it 5 days on? Is it 4 to 4 or 9 to 9?
How does long call work and is it junior or senior?
I will be commuting.
11 days off a month, 4 are "hard" or untouchable. The others can be moved (i.e. trip extended) but it's very rare. 5 days on would be common but it does vary a bit. You are assigned a protected time of 9 hours off the hook when you are on short call. Although you bid for protected times they can and commonly do change your protected time to suit their needs the day before so there is no consistency whatsoever.
Long call on the 190 is fairly senior. On the Airbus less so. 9 hour callout, but 95% of the time you will get your assignment by 1pm the day before when they process all the open time. It is possible for them to transition you to short call status with just 9 hours notice and almost no extra pay. Sucks, luckily it's also not all that common. More bad news for the long call guys is that you will get called quite a bit. Fairly common for long-call guys to fly 80 hours a month while the short call guys get 25 or 30. I went a whole month on short call once without getting called at all.
Essentially life on reserve for a commuter is not real great, nothing surprising there. If you live in base short reserve can be a good deal. The only saving grace for commuters given the crappy contract terms is that, in general, it seems like the schedulers are not out to intentionally screw you and will work with you a bit if you ask nicely (release you early from reserve on your last day etc.) Also commuting on mainline is not bad since you can reserve the jumpseat and you'll only get kicked off for a Fed or line check.
Have a basic question: Once the app is submitted, is there a need (or do they want you) to keep going in and updating times, etc.? Or does one submit the app and hope they call?
Thanks for any insight! My app has been submitted for about 10 days..
Life on long call reserve varies more by season than anything else. From September to February I average about 5 to 10 days of work. In the warmer months when most guys are on vacation is when you'll really fly a lot.
Usually guys and gals that live in base will bid short call reserve. Generally you fly less and you get a min guarantee of 76 hours a month. The commuters generally bid long reserve, but in this case you get a min guarantee of 72 hours a month. That usually describes the situation better than simply saying that people with seniority bid one way or another.
If you're a long call reserve and you get transitioned to short call you can check the computer the next day and see if they have adequate coverage. If so you can call scheduling and get "un-transitioned", which most times they will do for you.
