Hand Tools
Swass
So long, America.....
What brand of hand tools do you guy's prefer? Is there a clearly better choice of tool manufacturer, Craftsman over Matco etc.? I've always assumed that Snap On was the choice of most. I just wondered what you guys use most.
Snap on is #1, but the the price is just to frikken high.
Most of my tools are Craftsman.
Ditto,
Actually, since I am the cheapest one here, I will admit that I have gotten most of my tools out of harbor freight. That way, if I have to chop, bend, or otherwise modify them I can spend $20 and get a whole set and not just one snap-on.
Before I discovered harbor freight, I had invested in craftsman. Pretty smart move since there is a Sears is in almost every mall and Home Depot will also change out a broken tool for a Husky.(or atleast they use to)
Let's see if the Snap-on, Mac, or Matco dealer will change out a tool @ 6p.m on Sunday night!!!
It seems to me that the only advantage of MAC and Snap On is the on-site replacement of broken tools. That doesn't seem to be enough of a reason to justify the price over guaranteed-for-life tool lines like Craftsman, Husky, and Kobalt. You can save a lot of money if you don't mind driving to the store to replace a tool!
Ditto... of course having a relative managing a Sears makes the choice easy for me!
I've been a craftsman fan for a long time. I have almost everything that Craftsman makes, or has made. However, there are tools for various applications that Craftsman doesn't make. For those I usually buy MAC, or Snap-on.
My boxes are all craftsman. I've fallen in love with a couple of different boxes from both MAC and Snap-on, but after watching shopmates over the years overextend themselves beyond belief just for their box, no thanks. Plus I feel guilty putting stickers and junk all over a twenty five thousand dollar box...when I can have a Craftsman professional for far, far less.
I have a set of MAC open ended angle wrenches that I use mostly for hydraulic, that have been invalueable. The set ran about eight hundred dollars. When I got it, I bought one wrench each time the truck came around, paid it off, then got another. But that one set has seen just about as much use as most of the other tools put together. I have a few different quarter inch drive items, both Craftsman and Snap-on, that are in the same boat, and my Craftsman stubby combo wrenches have been practically worn out.
I fell victim to the need to have reversible ratchet box end wrenches, and found that the craftsman work as well as what I could get off the trucks. I bought some off ebay, bought some in the stores. The reversible kind with a lever to reverse are wonderful, as are the flexhead ratcheting box ends. I use them timing someone's car yesterday, and they stay with me most of the time. They see a lot of use. That particular set is Blackhawk, which gets sold at NAPA and other places, but I bought them from the MAC truck.
One thing I have learned is that you can buy quality tools now, or later...but you'll eventually need them. Craftsman makes great products, really good, functional products, and I like them a lot. But I've been places where only a snap-on socket would work, because it was thinner, and was the only thing that would fit. For a lot of turbine applications, I have used quarter inch flex sockets, and one needs a twelve point for that...six point from craftsman, and my twelve points are snap on. I think the little set of eight or ten was over two hundred dollars, and it was worth it.
Look for bargains...I got a full set of Snapon metric stubby combos last year in a gun shop...for a hundred bucks. Brand new, sold on commission. A little more expensive than Craftsman for the same wrenches, but let's face it...they were snap-on.
A lot of my screwdrivers are Craftsman, but my better ratcheting screwdrivers, long ratcheting screwdrivers, etc, are Snap-on. A few are MAC. Some of the speciality items are both. I have three or four different Dzus screwdrivers that have been picked up of the trucks when I didn't have one handy right then, about thirty bucks or so each.
I jump on the trucks and see what's on special. Some great torque wrench deals have been had that way, especially on repo equipment. I bought an infrared temp sensor of the Snapon truck once, with a laser. At the time I thought it might be useful, but I found it invalueable in doing cold cylinder checks...worked even better than a traditional cold cylinder tester (squirter bottle) when all the cylinders were close with just one bad plug...paid for itself in no time at all. Never thought I'd see that much use for it, and was wrong.
I did find that when calibrating Snap-on torque wrenches, we had a high failure rate...two of them broke our machines when they failed during the test. The best wrenches, most consistent, with the highest tolerances of any we were using were ADT, from a small autoparts store. They always tested better than the expensive Snap-on. I have the ADT, Craftsman, Snap-on, and MAC in my box, and use them all. So far, so good.
As far as Harbor freight...the engine timing I did yesterday was done where I didn't have my own timing light. I ran by harbor freight and picked one up. Nine bucks, cheap, and it worked. But for hand tools, or most tools, I'm very cautious. I had a set of large combo wrenches from there that I carried for a long time without every needing them. One day I had to remove the fittings from an engine driven hydraulic pump in the field, and they were tough to get off. Using the open end, I put some pressure, leaning into the wrench, and the fork snapped off, I went flying, got a nasty cut, and was stuck unable to finish the job. I threw the rest the set away, and vowed never to buy or own a cheap hand tool again. False economy if it doesn't get the job done. But for beater tools and stuff that's going to be cut up and welded into something else anyway...why not?
After all, show me a mechanic that doesn't have a box full of home made specialty tools. It can't be done.
It was a torque wrench, 30+ years old, and the Snap-on fellow changed it out with a functional version as a loaner 'til Snap-on repaired ours about 7:30 one rainy Sunday evening. We happened to see his truck parked at the local greasy spoon.
Snap-on came back and said we could keep the brand-new loaner as they no longer could make or repair the torque wrench.
I have a pair of needlenose Craftsman pliers that do not leave my flight case. I consider it an essential item. Ten years later they are still working just fine.
Fly SAFE!
Jedi Nein
I agree with avbug in regards to Harbor freight, very cautious on what I buy there. Although, one can never go into that store enough. A couple weeks ago I bought a texture sprayer for $29 and it works great. Also you can't beat the value pack paint brushes for your crappy applications that would otherwise hash out $10 brushes.
I'm not an aircraft tech, but we auto techs use the same brand tools that you guys do. I'm not brand-loyal, because I've found that each manufacture makes a certain tool better than the other. There's also the issue of price. For instance, I've found that Craftsman sockets hold up just as well as Snap-on, MAC, etc..The difference is that for $25 you can buy a complete Craftsman socket set, where Snap-on will just about charge that price for one socket!!!
My issue with Craftsman is that ALL of their ratchets are absolute junk! Even the polished professional units will snap the mechanism way too easily. The lifetime warranty simply means I'll be spending my lifetime running back to Sears for a new ratchet. For ratchets, I prefer Snap-on hands-down.
For screwdrivers, I've found that they all hold up about the same, but I prefer Snap-on because they seem to be the most comfortable.
For extensions I have a Matco set. They are knurled, so you can easily turn them with greasy hands in a tight spot. Craftsman does not knurled their extensions...
For regular wrenches I have also fallen victim to Snap-on. The Crapsman open-ends seems to flex open way too easily. Plus Crapsman does not even make special wrenches like my Snap-on 12-point, high-leverage, 0-degree offset box-ends. Those wrenches are well worth the cost as they are highly convenient.
For air-tools, I use Ingersol-Rand exclusively. Most of the "Snap-on" or "MAC" air-tools are nothing more than redecorated IR's. They also charge about TWICE as much for the SAME tool. For some it's worth it because most suppliers will in fact offer a 2-year warranty, whereas IR is only one. However, I have kept the tools well-oiled and use an inline water separator, and the IR's are still going well after 2 years.
My tool-box is a Crapsman. Strap-on charges WAY TOO MUCH for their boxes. I can get a pretty good sized Craftsman box for under 2K. Strap-on will charge 7K for a box with even less space. I simply cannot justify the cost, as the box really doesn't make you any money...
I've got a set of wobble snap-on extentions that are nicely knurled, but not as agressively as some. However, my craftsman extentions are knurled for spinning by fingertip, and they lock, which is nice. Nothing like hunting or a socket that dropped off the end of an extention when trying to do cylinder base studs at night off a ladder.
I have a couple of ratchets in box that are over 20 years old, craftsman both, never overhauled, still as strong as ever. I've never broken a Craftsman ratched, nor wrench. If it needs that much torque, then I'll go with a handle instead of a ratchet.
Most auto techs I know will stay away from Craftsman ratchets. I've had a couple 1/4 drives snap. I live close to sears so it's no biggy.
Interesting. Are they beating on them with hammers or putting excessive amounts of torque on them? I've never been able to hurt one. Then again...I treat my tools like I own them. ;)
In fact the only rachet handle I've ever had break or have had problems with has been snap-on.
NO probably just using them a lot more than the average aircraft mechanic. j/
Interesting, and I'll say that I'm also a big Craftsman fan as well. I'm actually an A&P student now (graduate in December) and 99% of my tolls in my school box are Craftsman along with an I-R air drill and a NAPA die grinder. And someone mentioned the MAC open end angle wrenches the ones that came with the set I have are Armstrong. As for what I have here at the house it's about all Craftsman again too.
SWASS!! Brother!! --- Is that you asking about TOOLS!???
How ya doing?
Most of my stuff is Snap-on, but I have
many others-the Mac angled open end,
some SK's that live in my truck with the
craftsman and others. Love my Snap-on
ratcheting screwdriver.
Last year I was changing the engine out
on my wife's car. I had the right-sized
craftsman socket on the crankshaft bolt,
leaned on it to brake it loose and the damm
thing slipped and rounded the bolt.
$!@@T!!!
Sooo I dug around and found the right
Snap-on socket, 'cept it's a 3/8 drive and
dosent want to fit the now rounded bolt
head. Drove that 12 point "flank drive"
on with a hammer, put the 3/8-1/2 adapter
in it and got the break bar on...My neighbor
had come over to help and was watching the
whole thing. When I got the bolt loose with the
"good" tool I could only look at him and say
"Snap-on. There is a difference."
Wouldn't ever willingly part with my 1/4"
drive Snap-on stuff...
I have a decent Kobalt box, and most of my tools are Craftsman. I do shop at Harbor Freight for things that don't really matter...huge savings over any of the big named tools. Hard to come by stuff or things I need on the spot I get from Matco since he comes to our hangar.
I've had to replace my 1/4" drive Craftsman ratchet once so far because the gears finally failed, but it was about 15 years old.
I use Hazlet wrenches & craftsman sockets & ratchets, no problem so far. the wrenches probably cost me as much as the entire toolbox and craftsman tools but they fit with no slop on nuts and bolts.
That's another thing. You cannot do without a complete 1/4 set. Snap-on wanted over $350 for the set of shallow, deep, standard, metric, extensions, and ratchet in a plastic case. It's a good set, but the price is a little high. I found an almost identical set from SK, and it costed only $150. When almost everyone is offering a lifetime warranty these days, it pays to shop around.
Mixed bag
You can find almost every manufacture in my box. Snap-on for the small stuff and a varied mixture for everything else. I love my S&K open end wrench set with a boxed ratchet on the other end. For ratchets Snap-on is the only way for me, it's the number of teeth and relative small movement that can actually work in a tough spot. Used to really like Dewalt but quality has really slipped lately. Of course Chicago Pneumatic for the air tools.
Just my .02
Well, I really doubt that. It's probably more a way of treating the tools than anything. Like I said, I've had some of my rachets for over 20 years with no problems at all. Some of them are old enough to still have the grease fitting in the end. And they've seen a LOT of use...the plating is long since gone, chipped off in some cases, worn off of parts in others, and still they haven't failed. If you're busting wrenches, you're doing something wrong.
Too True. Too True.
Well I don't Mr. Goodwrench. Ratchets are not created equal, and craftsman ratchets are known to snap.
re
Sure if you use them as breaker bars
A Corporate/General Aviation mechanic here, about 29 years worth. I still own and use the very first set of Snap-On tools I ever bought as an apprentice mechanic in my Dad's Aircraft Maintenance Shop in CSG. I also have a handful of oddball tools (Craftsman/Matco/Every-other-brand) that I'm willing to heat and bend, or cut and weld on.. to make that one-time special tool that absolutely no one manufactures. But by far, the Snap-On tools as far as I'm concerned, are worth every penny they cost.. in strength, specific fit and weight. I LOVE to have in my hands a tool that is so light that I don't tire of holding it, yet trust it to be strong enough to do what is required of it. I know the home address and phone # of every Snap-On dealer I've ever bought from in my area, and I have visited all of them on the odd after hours occasion that I needed to buy or exchange a tool.
I "free-lance" now and since I move from one customer's hangar to another as jobs change... my toolbox is a bit unique. I custom built a frame that holds a combination of Snap-On and Mac drawer sets, mounted on a set of 6 pneumatic casters (free-turn at each corner, rigid straight paired in the center). It will rotate in it's own length for ease of navigation around tight hangars, and has a tow-bar attached on a permanent hinge that folds upward like bar on a car towed behind an RV. I can hook it to my pickup and easily move across the ramp and between hangars. It has multiple electrical outlets wired to a reel with a 100' cord. The same arrangement has a series of air outlets connected by manifold to a single 100' air hose, I can plug in one hose and electrical cord and power up everything on my box, including a nice stereo to listen to :) I also have a full "Taco-Wagon" Snap-On box in my T-hangar that I can work out of when my normal tools are scattered hither and yon across the airport.
If tools are worth earning a living with, they're worth being the best you can afford.
"The bitter taste of poor quality lingers much longer than the fleeting satisfaction of low cost"
Dave Danger A&P/IA
Dave Danger A&P/IA
most of my tools are craftsman. but i love my snap-on screw drivers,would like to afford to buy there flank drive sets but will wait.Snap-on was the only place I could find a 6-point deep 5/32 for the relay hevan on the saab's but that only cost $12.00. Did find a nice set of SK's 1/4 drive 12-point universals for $135.0 at D&B tools. I agree with some of the earlyer replys about craftman wrench's speading, I have taken several back to sears for that problem,as stated earlyer someday the tool fairy (wife) will bring me some snapon's:) .As far as box's go i use a used KD Tools that i got for $100.00.love the ones from all the big names and if I planned on passing it down to my kids I might buy one.Think I will stick with sears or kobalt. I am not sure who makes the boxes for Home Depot but about five years ago they were made by mac,not as heavy but the same rolles and wheels.Just remember, If you can itamize on your taxes save all your tool receptsthey are deductable and helps to take the sting out at the end of the year:cool:
