Going to JS on Colgan Air from BOS-BHB
bothfly
Member
Any Colgan guys online?
I'm a SWA guy and I'm planning on trying to catch a ride with one of you this Monday, the 9th from BOS-BHB, and then back to BOS on the 12th or 13th. If anyone can check flight loads for me that would be great. Since there is no JS on the 1900. You can PM or just post. Also, let me know if I can bring you anything from Dallas, TX before I leave!
How does FLT 4967 BOS_BHB on the 9th look?
How does FLT 4963 BHB_BOS on the 13th look?
I work for XJT. If BHB doesn't look good Bangor is also an option. I grew up near there and BGR is only 45 minutes from Trenton (BHB) airport. XJT does at least 2 flights a day into BGR.
If you haven't been to Bah Haba :D before it has got to be one of the most beautiful places on earth. Check out Acadia for at least a day. Watch the sunrise on top of Cadilac Mountain, walk the rocks around "pebble beach". Good times. If you'd like me to check any BGR flights shoot me a PM.
Steve
bothfly, they run 4or5 trips a day. you should be able to get on 1 of them. they also will put as many non-revs on as they can accomidate. weekends are heavy,but you should be able to get there and back without a problem. Arcadia=Awesome you have to check it out. Also HOW DO YOU GET INTO SWA!!!!!! Have a great time
