global express thoughts...
doublepsych
just had my first trip in our glex, which is about a week old. beautiful airplane, awesome cabin. what irks me is this: no AOA info. been flying a competing brand, and I have evidently gotten used to that info more than I realized. Plus this global is not quite as comfortable (maybe idiotproof) at altitude as a G. You really have to watch what you're doing when selecting when to step up on altitude. Definitely possible to be plowing along for a while waiting to lighten up, and that alpha info would sure be nice at that point...Never really seen a gulfstream level off and have trouble maintaining speed, and that kinda messes up the crew rest. If any experienced global guys would be kind enough to share any rules of thumb on cruise alt selection or any other wisdom, it'd be much appreciated.
thanks
CL-604 system
I flew the challenger 604, and it had a stall protection system that you tested on the ground. It was mounted on the side wall besides each pilot. It would sweep just like an AOA and then start the stick shaker. Does the Global have that system? If it does than that IS a Kind of AOA. Once time while eating my dinner at cruise the thing came off the peg and started to move like on the ground test. Next thing you know the airspeed is decaying and pitch is starting up. We were in mountain wave at FL370 over Denver.
Well ...
The only thing similar between Global and Gulfstream is they both start with a "G". However, the "G" means "Gulfstream" ... now you've learned.
Gulfstream's motto "Never surrender, never compromise".
Ofcourse that also means never lower costs.
TransMach
Do a search on some of GVFlyer's old posts. He compares cruise altitude capabilities of the two (when he was a Gulfstream test pilot, he did a test of a GEX that Gulfstream received in trade). Might be helpful.
thanks
You don't have the cruise information in your manual that came with the airplane? :confused:
Experience can tell you a lot more than a manual. Hearing how the airplane behaves in the real world is a lot more valuable to me than what a manual can tell me, and what better way to get first hand information then to ask the guys who fly them.
I think Bombardier decided pilots are not smart enough to let them have access to AOA information in flight - It's missing in the Challenger 300 as well...
It took a little while, but I got used to not having it.
thanks
We cruise at M83 instead of M85 now after a few interesting experiences in the mid and high 40's. Seems to keep speed better, less overspeed tendencies than when at M85 with minimal time loss and fairly significant fuel savings on long flights.
Hope this helps,
FF
Get used to the fact that you now fly a Global. It will never be a Gulfstream in terms of reliability and rock solid performance.
The quicker you learn to live with it, the less irritated you will be.
BTW - there is a way to display AOA. When you learn more you will figure it out.
Airpedro - ex G pilot.
Unlike takeoff and landing data, cruise manual data is not certificated data - it need only be "representative of flight test article in the flight test program". Subsequently, many manufacturers, Bombardier included, gather this data during function and reliability testing during the certification process in "green" aircraft . As a result, most cruise manuals are optimistic.
In the case of the Global we tested, the cruise manual was up to 11% off. It would not make the charted altitudes or speeds for weight and atmospheric conditions. We found that FL430 was a good mid-weight or lighter altitude. Experience in your particular aircraft and advice from other Global Express operators should serve as a good operational teacher.
It's a good thing the aircraft is selected and paid for by the people in the back. Of course, GV will tell you that all passengers prefer the smaller cabin of the GV versus the Global as it's more "intimate" and the 650 was driven more by the marketing department and less by passenger input.
From a passenger perspective the GLEX is the ultimate, it has ramp presence unlike any other business jet out there(excluding the big Boeing and private airbus products). The back is very roomy, and can be made up beautifully. But from a pilots perspective nothing flies like a Gulfstream, so I am happy with my job, but we have been hearing a few rumors that the boss is shopping for a BD-700.
Brand new green airplane from the factory I hear is about 35M with interior running anywhere from 10-20 million.
I know of a F500 company with a lower serial number Global who had to chase it every flight with their Challenger to have another aircraft available in case of maintenance problems.
The Global Express cabin is 10 inches wider than the Gulfstream G550 cabin. The G650 cabin is 53'7"L x 6'5"H x 8'6"W. Buy the cabin that is appropriate to your mission, but in the process remember Gulfstream's basic design philosophy: No Compromise - Performance First.
Let me explain by comparing the G550 to the Global Express XRS. The thrust deck or propulsive power (Wpa) available determines the aircraft volume that can be propelled through the air at a given speed.
As such, with the same engines (R/R BR710 - G550 - 15,385 lbs thrust, Global Express XRS-14,650 lbs thrust), the volume of the G550 and the Global Express XRS is roughly equivalent. Bombardier spent more of their volume on cabin, Gulfstream spent theirs on wing. The Gulfstream has 1136.6 sq ft of wing, the Global has a 1022 sq. ft. wing The resultant is that the Global is a high wing loading, point design, buffet limited airplane and the Gulfstream is not. In addition to reduced margins, the Global also pays for its cabin design with increased total parasite drag - which is why it has never made advertized range.
In the real world, passenger comfort has a lot to do with how long a passenger is stuck in the airplane. I recently took off from London heading to LAX. Prior to my departure a Global Express took off enroute to Columbus, Ohio. I flew over him by 30 West and landed in Los Angeles 10:29 after takeoff, running against the wind - that to me equals rapid transit and an enhancement to passenger comfort over any other way my passengers could have traveled to LA.
Having not experienced BBD customer service, I can only repeat what I've heard but I DO know that GLF will move heaven and earth to get you moving.
We fried a MAU 3B card (PIC PFD, EGPWS, L Cursor control,Radio tuning--stuff you'd need in the left seat) in Mumbai. Swapped with another, less critical card and continued. The next day in Delhi, the card showed up (shipped from SIN). It was the wrong one. GLF had a courier hand carry the correct card from Luton so we had it fixed before we left the following day.
I never worried about getting stuck somewhere with a broken Gulfstream.
TC
Good point !!
If you want AOA and other flight parameter info, try pressing and holding the Air Cond and Flt Cont MFD synoptic buttons down at the same time. Should enable the flight test synoptic on the stat page.
Try the HUD.
