Cactus Charlie
- Mar 1, 2025
- CCX-2000 (FX-3)
- KDVT
- Commercial ASEL, ASES, AMEL, glider. CFI glider, ASE, Instrument.
Last weekend I became aware that Garmin had, back in May 2023, introduced a GSA 28 servo service life extension program. It seems that Garmin had found that a batch of GSA 28 servos manufactured between September 2021 and January 2022 had been built with one or more substandard parts. Garmin initially issued service bulletin 22016 for these specific serial numbers.
Later Garmin issued two more service bulletins, 23024 Rev A for type certificated aircraft, and 23038 Rev A for experimental aircraft. These SB offer free replacement of a wide range of GSA 28 servos with the offer effective for 5 years after the date of the SB. This covers servos with expired warranty and regardless of time in service. This program ends May 2028.
While doing the research on this program I collected a list of references that may be useful. There may be some duplication and the references are not in date order.
Vans announcement and discussion
Service life notification
Non experimental SB 23024 rev A
support.garmin.com
support.garmin.com
support.garmin.com
Experimental SB 23038 Rev A
support.garmin.com
Initial SB 22016 reference only a limited range of early servos.
support.garmin.com
FAQ
support.garmin.com
SB 23024 impacted by serial number
support.garmin.com
SB 23038 impacted by serial number
High level info links
support.garmin.com
Garmin GSA 28 Servo Service-Life Extension (Service Bulletin 23038)
Good Morning, We released a Service bulletin today that outlines a Service-Life Extension program for our GSA 28 Autopilot Servos. Garmin has implemented several design and manufacturing process improvements to improve GSA 28 reliability. The latest update has been added to a consolidation of...
vansairforce.net
Garmin | United States | Aviation Support
Garmin Aviation Support Center is where you will find answers to frequently asked questions and resources to help with all of your Garmin Aviation products.
(2023) Service Bulletin 23038 Rev A: GSA 28 Service-Life Extension Program (Non-Certified) | Garmin Customer Support
Garmin Support Center is where you will find answers to frequently asked questions and resources to help with all of your Garmin products.
(2023) Service Bulletin 22016 Rev B: GSA 28 Servo Mod 1 | Garmin Customer Support
FAQ
