FYI Garmin G3X touch (experimental) 10.0 released
Change History​
Changes made from version 9.52 to 10.00:​
  • Added support for GCO 14 carbon monoxide detector
  • Added support for GDL 90 RS-232 traffic data
  • Added heading bug auto sync mode
  • Added shortcut to set baro minimums by touching bottom half of altitude tape
  • Added configuration option to invert PFD lateral deviation when in reverse sensing region
  • Added configuration option to confirm calculated fuel quantity before every flight
  • Added additional configuration options for Vertical Power volts/amps gauges
  • Added support for custom calibration of magneto P-lead and electronic ignition RPM inputs
  • Added support for configuring GTX 45R/345R RS-232 ports for Traffic Format 4
  • Added support for Kavlico P500-75A fuel pressure sensor
  • Added support for ULPower FADEC manifold temperature
  • Added ability to adjust fuel flow calibration offset for FADEC engines
  • Added audio alerts for autopilot airspeed limiting
  • Improved weather data processing
  • Improved NEXRAD display on map page
  • Improved handling of 8.33 kHz COM frequencies on GTR 205 / GNC 215
  • Improved engine page and EIS display
  • Improved discrete input operation on GEA 24 #2
  • Improved configuration of thermistor CHT gauge markings
  • Improved rotorcraft RPM display
  • Improved checklist file processing
  • Improved traffic data source selection when both TIS-A and ADS-B are supported
  • Improved status display for GTX ADS-B traffic data when TAS/TCAS correlation is supported
  • Improved automatic flight plan sync via Connext interface
  • Improved handling of external flight plans with parallel track offset
  • Improved AFCS operation
  • Improved CWS operation
  • Improved PFD visual contrast
  • Improved data logging
  • Changed Vne audio alert
  • Changed map orientation override to be preserved when moving between pages
  • Changed location of startup database info page to be configurable
  • Changed VFR/IFR charts page to show track vector if enabled
  • Changed GTX 3x5 configuration to support standby flight displays connected via HSDB
  • Changed maximum fuel flow calibration offset to +/- 15%
  • General improvements to system operation
  • Includes update to G5 SYS 8.80
  • Includes update to GAD 27 SYS 2.90
  • Includes update to GDU 4xx audio database 3.00
  • Includes update to GDU 4xx timezone database 42.00
  • Includes update to GDL 5x 2.32
  • Includes update to GEA 24/B SYS 4.40
  • Includes update to GHA 15 SYS 2.15
  • Includes update to GMA 245 SYS 3.30
  • Includes update to GMC 507 SYS 3.30
  • Includes update to GPS 20A SYS 2.60
  • Includes update to GSA 28 SYS 5.90
  • Includes update to GSU 25 SYS 4.60
  • Includes update to GTR 200 SYS 3.70
  • Includes update to GTR 2x5XR SYS 2.32
  • Includes update to GTR 2x5R TSO SYS 2.32
  • Includes G5 BB 2.40
  • Includes GAD 13 BB 2.00
  • Includes GAD 13 SYS 2.10
  • Includes GAD 27 (-00) BB 2.30
  • Includes GAD 27 (-10) BB 2.00
  • Includes GAD 29/B BB 3.10
  • Includes GAD 29/B SYS 3.40
  • Includes GAD 29C/D BB 2.00
  • Includes GAD 29C/D SYS 2.10
  • Includes GDL 39 4.91
  • Includes GEA 24 BB 2.20
  • Includes GEA 24B BB 2.00
  • Includes GHA 15 BB 2.00
  • Includes GI 260 BB 2.20
  • Includes GI 260 SYS 3.00
  • Includes GMA 245 BB 2.40
  • Includes GMA 245 BT 2.00
  • Includes GMC 507 BB 2.30
  • Includes GMU 11 BB 2.10
  • Includes GMU 11 SYS 2.20
  • Includes GPS 20A BB 2.10
  • Includes GSA 28 (-00) BB 2.20
  • Includes GSA 28 (-20) BB 2.10
  • Includes GSU 25/B BB 2.30
  • Includes GSU 25C/D BB 2.10
  • Includes GSU 73 FPGA 2.02
  • Includes GSU 73 SYS 3.80
