semperfido
Keep Humpin
- Dec 5, 2004
I adapt to stuff that WORKS. I don't adapt to stuff that presents a potential safety issue. Auto-retard does IMO.Do you have "steam guages" in your GIV/GV, or did you adapt to glass?
I adapt to stuff that WORKS. I don't adapt to stuff that presents a potential safety issue. Auto-retard does IMO....
If they're that bad then maybe you should have maintenance figure out what the problem is. All in all, the autothrottles work fairly well in our two airplanes. I'm a believer in flying the airplanes the way they were designed to be flown. I also fly a Falcon 2000 with no autothrottles so should I leave them off in the GV for consistency? So I don't forget what airplane I'm in....come on now.
Watch 8 or 10 people land 1500 feet long because of the auto-retard feature and get back to me. Not talking about auto-throttles. We're talking about 50' AGL auto-retard. Big difference.
Let's just say, the auto-throttles work as advertised. I just don't like the commercial.
(Kind of like that dorky SWA commercial with the F/O and a guitar...)
The EGPWS (call outs) and the A/T system both use the Rad Alt, but the EGPWS does not tell the A/T system to pull back to idle. If the a/c detects landing config than the RAD ALT is whats telling the A/Ts to pull back so I would suspect the RAD ALT system. You can test them both and make sure they go to 100 ft + - 5 ft ( they should be at -5 ft on the ground) also I think that the A/T system is using the RAD ALT that is selected on the pilots Display controller so you could try flying with #2 RAD ALT selected. If that does not work try Boxing the #2 A/T computer. Has for the 5000 ft runway I don't understand how that would effect it. I hope this helps.
I don't understand whynpeople are floating aswell using the auto throttles. Auto retard at 50 ft is the same as you manually bringing throttles back at 50 ft. So the guys floating 1500 ft has nothing to do with the auto throttles but more like landing technique and trying to grease it on all the time.
IMHO, if your holding your Vref + wind correction speed to 50' (for the G550, that's Vref +20), it's going to float.
During takeoff, I advance the throttles almost to the desired EPR, then engage AT, that way I can control the engine acceleration and still get the desired power setting.
On approach and landing, I'm guarding the throttles all the way down to touchdown. If I have wind correction added, I start bleeding off the excess speed around 200', manually (disengaging the AT) works better for me, verses clicking off manual speed and switching to autospeed. If while on AT, I enter a shear, I correct by overriding the autothrottles and push/pull the throttles as necessary. At 50', if I'm happy with my speed (and trend) I let the throttles do their thing; to fast, I pull power early, slow, I hold the power in. This works for me just fine.
The system is only as good as its operator. Like the autopilot, never trust the automation when close to the ground, which means that one had is always on the yoke, and the other hand on the throttle (in our SOP) anytime the RA is active. Also, know what mode you’re in, how the automation will comply, and what you’re actually trying to do. Seen people command a descent, while on autopilot, click off the autopilot and level off. All the computers know, is that you want to descend, hence the power is reduced (or at idle), aircraft is level and the pilot is wondering why the throttle aren’t reacting. I always get rid of the flight director when maneuvering visually, say on a visual approach, with no lateral or vertical commands left in the guidance panel, other than speed. Works great, and haven’t been surprised.
