Clear-&aMillion
- Nov 19, 2005
FracCapt said:Jet A does not have the lubrication properties that Diesel/heating oil does, because in a turbine engine there are no parts requiring lubrication by the fuel.....the same is NOT true with engines that run off of diesel/heating oil. You may have fried a bearing that is lubricated with the fuel.
Hopefully, all that needs to be done is mix sufficient heating oil with it to make it burn properly(since Jet A has a higher flashpoint, though not much)...but I suspect you caused some damage.
A trick I have learned over the years operating diesel engined vehicles is that if you put something like Jet A in it, or even end up with half a tank or more of gasoline in a diesel tank, is to mix a quart of oil into the fuel, or dump a few quartz of Crisco in it for lubrication properties.
A diesel engine will burn gasoline...but the lack of lubrication is what really destroys the engine. Same with your furnace, I suspect.
atr42flyer said:im glad you said that i should dump crisco in it i was worried that was the problem in the first place.
Clear-&aMillion said:The DA42 can operate on both diesel or Jet-A. Pretty neat.
Actually, it can not operate on US diesel, at least not yet. It needs a purer form of diesel, available in Europe. US diesel fuel has to much sulphur in it for the DA42. That's why, even though it is a diesel engine, it needs Jet A.Clear-&aMillion said:The DA42 can operate on both diesel or Jet-A. Pretty neat.
