Flying outside the US with an Experimental Cert?
Diesel
TEB Hilton resident
I know I can ask the guy that assigned the cert to us but I'd thought I'd ask here to.
We are currently operating with an experimental/ market survey registration "pink copy".
It says in our experimental manual that if we want to operate outside the US airspace ie Canada and the bahamas we must apply for a waiver to do so with the country we want to fly into.
Has anybody ever done this. Not being able to fly into canada kind of sucks and I want to apply for a waiver from Canada. The web wasn't much help.
Anybody know where to start (other than the FAA that issued this cert)
Thanks. Once again I know its odd but I thought someone might know this.
Don't know if market survey is any different, but exp/amateur built fly internationally just fine. If you want a nice write-up of going to Mexico, take a look here:
http://www.rvproject.com/2005_mexico_intro.html
and
http://www.rvproject.com/2004_mexico_trip_log.html
Canada seems to be even easier :)
This is stuff that relates to amateur built going into Canada:
Operating U.S. Amateur-Built Aircraft in Canada Similarly, Transport Canada authorizes U.S. Amateur-built aircraft to operate in Canada under the terms of its Standardised Validation of a Special Airworthiness Certificate-Experimental, for the purpose of operating a United States-Registered amateur-built aircraft in Canadian airspace (PDF).
For more information, visit http://www.tc.gc.ca/civilaviation/maintenance/aarpe/Recreational/menu.htm.
Not sure how helpful this is to your market survey bird.
Not sure of the paperwork, but I mentioned in the RV thread that I saw no less than 6 RV's parked in a row at Cozumel a while back. So it can be done, probably pretty easily.
But your pink (temporary)registration is only good in the US. Call the FAA registration folks in Oklahoma City, and get a telegraphic registration, its good outside of the States. A telegraphic is not a temporary, thus good. This is what we use on newly delivered airliners to operate in Canada and Mexico.
Can't comment on the "waiver" in which you ask, but I CAN comment on the "pink slip" registration. And that is you CAN NOT operate internationally on a pink slip. ONLY OKC transmittal OR permanent registration accepted for international travel.
End of story
