Flight Sim 2004 help (?)
onthebeach
Total Time
10K+
Just playing around with flight sim 2004, century of flight.
How do you fly the sailplane? Can't seem to set it up at altitude & obviously can't power it off the ground.
Thanks in advance...
CaravanMan
Drop eet like eet's hot
Total Time
Some
I haven't played it in ages, but I believe the "Y" key is the slew key. Press that and then you should be able to move the plane horizontally anywhere, very fast, by using the joystick. While in Slew mode, pressing F1 thru F4 keys control your altitude. If you hit F4 it will take you up, pressing F3 stops you. Go up as high as you want, stop, and press "Y." You should be set! Hope that helped!
apcooper
Dude, where's my country?
Total Time
a lot
You will have to slew it up to altitude. Hit the Y key and then F4 and you will ascend very rapidly. To stop hit 5 in the numberpad on the right side of key board. To undue slew hit Y again and you are all set.
FlyChicaga
Total Time
4500
I haven't played in years, but in the older versions I'd fly the Cessna up to altitude, then switch aircraft to the sailplane. You'd start in the same position and speed as the Cessna. I don't know if it's the same.
SammyG
I hope its big enough
Total Time
150Hrs
I think you can use the "Map View" function, under one of the menus, to select your airpseed, altitude, heading, and location, just by typing the values in and then hitting ok, and it'll put you right there.
MFRskyknight
Don't F with Chuck
Total Time
low
I've had FS04 for months now, and since that automatically makes me a qualified 747 captain who knows everything, I can help you out. Like Caravan said, you can get the sailplane going by switching to Slew Mode (that's hitting the "Y" key), and using F1-F4 to control your altitude, etc. In Slew you can also use your joystick/arrow keys to change your lat & long. Nothing as fun as hooking that baby up to another plane, unfortunately.
I don't know if you do this already, but if you have broadband the Multiplayer function can bring another dimension of reality and fun to it, provided you have a decent computer system and join the right bunch of people.
Hope this helps.
-MFR
MarineGrunt
Will kill for peace.
Total Time
G 2/24
While we're at it, does anyone know how to make custom callsigns instead of using the standard "Landmark" or "Orbit" ones...?
UnAnswerd
Activity Terminated
Total Time
NA
Holy crap!!! With the "slew" option, you can take the 172 up to 99,999' MSL!!!!
minitour
Download the "Delta" or "Citrus" repaints....it's kinda neat....kinda nerdy, but I like that some time.
-mini
Singlecoil
I don't reMember
Total Time
8760
NTXPilot said:
Anyone remember flight simulator on Mac? Yeah, I had that...
I pretty much learned to fly on that one. I still think that was one of the best versions. I liked the WWI game as well; getting your fuel shot out and having to glide back to base. Ahh, memories.
flyifrvfr
Banned
CFII/MEI right seater
Total Time
725
If you like helicopters you can download some from hovercontrol.com. Very cool site.
