Flight Options Dedicated Crewing
RJL
Good Morning All-
I read with interest a new Flight Options ad talking about "dedicated crewing." Can any of you Flight Options pilots or candidates tell me what this means? Is a Captain and/or F.O. assigned to just one aircraft? What happens during maintenance? Do you fly other aircraft or are you grounded until your personal aircraft is ready?
Sounds like an interesting concept, but I don't totally understand how it works or if pilots like this or not? I also don't understand how it works with the scheduling.
Thanks-
RJ
At Options, there are two crews per airplane (4.7 pilots/aircraft). The schedule is 8 on, 7 off, so the crews rotate every week. All pilots are assigned a specific N # to fly, and they stay with that airplane until they change seats or equipment. Since FO deals with used a/c, one Beechjet may be configured differently up front than another one, the crews can get used to one particular aircraft and fly it all the time.
If you are on maintenance, you stay with your airplane wherever it is being serviced. I'm just an FNG so if any other Options guys out there can chime in, please do!!
I am at Flight Options and like the one dedicated crew concept.
For the most part the captain stay on the same aircraft all the time and the FO is sometimes switched out. The only time when the captain is not on his aircraft is when he is on vacation or if a check airman is going to do IOE with someone and they need an aircraft.
You get to know your aircraft and the crew flying it on the other week so you know who to blame if there is not enough diet coke on board the aircraft.
The best part for me is that I can track my aircraft the day before I go on duty to see where it ended its last trip so that I know early in the afternoon where I will be flying out to the next day.
(Before dispatch figurers it out and gives you your travel info)
EJA_PIC
Looks good on paper but what happens if one plane breaks? Can you take another tail number that may be at the airport? What if one crew member gets sick can you swap another pilot from a different tail number to fill in.
Does it get old flying with the same few people over and over again? Can you say complacency?
From what I have seen there are so many different configurations in the cockpits and equipment they had to do it.
How does this impact the passengers if there is an operational problem with the dedicated crew/plane?
Dedicated crewing
"Looks good on paper but what happens if one plane breaks? Can you take another tail number that may be at the airport?"
If there is another airplane there, then there should be another crew. If they cannot do the trip due to duty time issues, the Program Manager or Chief Pilot must approve the crew flying the other airplane. This rule has been pretty lax in the past, but due to some recent issues with Captains not flying their assigned airplanes for extended periods of time, they are cracking down on scheduling. They are not allowed to schedule a Captain as PIC on any airplane other than their assigned. A Captain can be assigned as an SIC on an airplane other than their assigned, and F/Os can be assigned any airplane.
"Does it get old flying with the same few people over and over again? Can you say complacency?"
I seem to fly with a different F/O every two or three tours max. I have not flown with the same F/O for more than three tours in a row.
"From what I have seen there are so many different configurations in the cockpits and equipment they had to do it."
So how many Flight Options airplanes have you been in? You're just "checking out the competition", right? Yes, there are some differences, and as you know each airplane has a personality all its own. The PIC knowing the history of the airplane helps reduce maintenance problems.
"How does this impact the passengers if there is an operational problem with the dedicated crew/plane?"
What kind of "operational problem" are you referring to? Maintenance problem? Another crew/airplane. Duty time problem? Another crew/airplane. Seeing a trend here?
um, "duty time problems"? I didn't think we had "duty times"! Let me know if i'm missing something.
"Yes, there are some differences, and as you know each airplane has a personality all its own. The PIC knowing the history of the airplane helps reduce maintenance problems. "
How could knowing the history of the airplane reduce maintenance problems? It's either broke or it isn't. This smells like: "The PIC knowing the history of the airplane helps him/her know when to write up a problem and when to ignore it cause it ain't gonna get fixed."
When your plane is in Maint. most of the time they will let you sit at home and you still collect perdiem, time to go out to eat, especially, since we get $40.80 per day while scheduled on duty whether at home or on the road, GREAT DEAL:cool:
I have been flying with the same guy for almost 8 months.
After the first 3 tours the program manager asked if everything was cool between us and if I wanted to rotate out or stay with him. Since we got along good and there was no ego problem. I decided to stay and it was great. If I wanted to or if he wanted to we would have been rotated around.
As for what you do if your aircraft is broke. I stay at home until it is fixed and get paid!!!!!
I had one whole tour at home and got a lot of yard work done.
TDvalve
If an airplane has an oil pressure gauge that always went to zero for 5 minutes after takeoff but worked ok all other times then thats how a Captain knowing the airplane would be an asset. A new guy may ground the airplane at the next landing or even return to the airport. If you have flown the airplane often you wouldnt inconvenience passengers and cancel trips for something that could wait for the next scheduled check. Jets are strange machines and many have unique faults that once a pilot gets to know can be worked around. Otherwise most airplanes would be hangar queens 24/7.
Also some airplanes may fly differently or wear parts differently such as tires, brakes, hot sections, etc. If I fly an airplane that always pulls a bit to the right on landing I will anticipate with thrust reverser or rudder rather than wearing out the brakes on one side prematurely and causing 2 trips to mx instead of one.
It seems like with jets its never as simple as "its either broke or it isnt"
"You are kidding. Right?"
If he isn't kidding, things are worse at FO than I ever imagined. Don't know whether to laugh or cry!
I forgot about the disclaimer: The above doesnt apply if you work for an airline or if you are represented by a union. The rules regarding common sense are different
"I forgot about the disclaimer: The above doesnt apply if you work for an airline or if you are represented by a union. The rules regarding common sense are differentThanks for clearing that up!"
I feel all better now knowing that the absense of a union turns unairworthy airplanes into airworthy ones. Why don't you share your maintenance philosophy with your owner/passengers? While you're at it, you might find it helpful to educate your insurance company and the FAA about FO's definition of "common sense". Then again, maybe your post has already accomplished that.
Vow Flydog!
Your post was all good untill the poor example. Union or not, that hypothetical airplane better be grounded now. Well, I hope it is just hypothetical. Is it?
I have been at Options for almost 3 years and have never come across anything like that.
If it was broke you just wrote it up and it was fixed. If you didn't write it up and flew an aircraft in that condition not only are you risking your career but more importantly the lives of the people on the aircraft.
A guy who would fly an aircraft like that at Options would have been already out the door and would be looking for a company with a union to protect him next time he did something stupid like that.
I was being sarcastic in my response to Valve
We all know that TDValve Mr 767 pilot has never flown an airplane with any broken parts in his 14,000 hrs.
I wonder if he would declare an emergency and shut down and engine if his N1 gauge quit working while the N2, oil press and temp were all normal. I know guys that have and they didnt get to keep their job. Part of this job is thinking through problems.
The point of my original post is that minor items that are known by a pilot to be a simple case of a stuck needle and not a major engine malfunction can be deferred.
I wont ground an airplane just because the light bulb on the VSI doesnt work but obviously the rules are different for 121 so the perspective for a 121 pilot is different. Us lower time guys grinding it out in 135 in 25 yr old jets unfortunately dont have the luxury of refusing trips when nonessential items break unless its a threat to safety.
By the way I dont work at FO so dont take my response to mean this is how their SOP dictates handling mx squawks although I am sure most of their pilots use common sense when they find a light bulb burnt out.
Flydog, actually I didn't do my first solo in a 767. And, no, I wouldn't shutdown an engine and declare an emergency for an inop N1 indicator. I would write it up at the completion of the flight. However, if it was inop before takeoff I would either get it fixed or deferred in accordance with our MEL.
You might want to look further if you really think maintenance requirements are strict under 121 and lax under 135. The Part 135 maintenance requirements for transport category aircraft was lifted almost verbatim from Part 121. The biggest difference between 121 and 135 is attitude.
I know the 121 and 135 mx rules are similar. The ethical mindset of the employers however are different and if you dont have an MEL it gets even murkier.
Is it legal to fly with a burnt out light bulb on a map light without an MEL? My FSDO says no. Would I be fired if I refused to fly with a map light out? Probably.
What about the good old "Could not Duplicate" mx response. If this same part continues to fail and its not a safety risk do I quit my job in disgust and complain to the FAA or just take it in stride?
So what do I do. Lose my job over a stupid lightbulb and file a lawsuit and make a big stink about it to the Feds? I dont think so.
Dont preach 121 ops because even though the regs are similar in the real world we dont have the luxury and the backup of a Union, a professional standards committee and any of the benefits of flying for a major airline.
Some employers may be more safety oriented and ethical than others. Most 135 operators are interested in making a buck and care about safety second. The whole point of my post is that you cant fight the system and you as the PIC have the final authority for the safety of the flight. This is where the PIC knowing the airplane comes into play.
If you want to become a martyr for the cause come on down to 135 and do a few trips.
I really dont know what your point is. Either you are trying to show that I am a sucky Captain or that no one should fly an airplane unless all the Ts are crossed and Is are dotted. The latter doesnt exist in real life and I wont debate my decision making and job performance with you.
dedicated crewing and other crap!
Gentlemen:
As Aformer Flight Options Captain, actually, one of the first, let me explain the dedicated crewing "concept". It all started because the Hawker and Beechjet crews couldn't keep all the different avionics packages straight. Very simple keep the crews in the same airplane. The problem now is that "uncle Kenn" (I could never figure out the two N's) has tried to manipulate this into a marketing point, the people they sell to are not that stupid, just a bit frugal.
As for the MOOK who made the comment about the oil pressure gauge, it's because of people like you that I no longer fly for FO. I cannot fathom why the mentality of write it up later or "I know we've been up for sixteen hours, but let's fly anyway" still persists. I hate to see you guys learn the hard way.
It's unfortunate that punks try to pass themselves off as professionals.
Don't even think of Flamin' me Kidds
KiddDynomite
Hey, why all the stars on the FO posts
Hey, just an observation...ok 2 observations.
1. Why do the Flight Options related posts have stars next to them and none of the other subjects do? :-)
2. Of course you have dedicated crewing. When you are flying a bunch of old clunkers that are not standardized, you need to keep the same guys on them so that SOMEONE knows the quirks and the mx history. :-)
Come on now guys, lighten up.
By the way, having said that, dont we ALL fly used aircraft. After all, once you pick it up from Wichita, its used, right? :-)
Kid dynomite
KiddDynomite
You said that you were at Options a while ago.
I think we flew together.
Does Rochester, NY mean anything to you?
And were you a former Miller pilot?
Let me know So that I know it is you.
The stars are the rating given by users. you can rate a thread by clicking the link at the bottom of the thread. 1-5 stars
I've read this thread with fascination. Ok my spelling sucks but here goes.
I came from a small 135 operator where every trip counted. I loved the man I worked for like a father. Most of us were A&P's and he was an IA. I wasn't an A&P but that was because i was too lazy to take the test.
We used to do cylendar head changes on the ramp in HPN when a plane went down. Every day when I went to fly I knew that every trip counted and we had a mission to do.
So I would make sure I got every trip done. If something broke I knew why but I would make sure the trip would get done. WITHIN REASON OF COURSE.
...... Then i came to EJA. All during aircraft training my questions were, what circuit breaker resets that, how do I turn that light off.... stuff like that. I had my leatherman and I was ready to fix anything that broke on the road.
Then I went on the road and it was like someone kicking me in the NUTS. It's safety stupid that's the motto here. I couldn't believe it.
If a lightbulb was burnt out or something wasn't just "feeling right" we're done, and a maintenece guy comes out and works on it.
I can't describe when I cringe on the phone about a writeup and the PM and MX supervisor says with a cheerful voice "don't worry about it we'll take care of it right away, your all done we'll work on hotel info asap."
We work on the big picture here, if you break down someone else will swoop in and pick up your pax. There is NO pressure on us.
I just grin and smile. The fractional industry can't afford an accident or a death. I make sure I let all my owners know how safe this place is.
All I can say is thank you EJA for keeping me safe. I know it's sappy but when I look back I realize how close I was towing the line. JP you know what I mean.
Hey Flydog,
You need to learn to pick battles more wisely, 'cause you're gonna lose this one. Only a two bit puke who has no substance, character, skill or a set between his legs would act like you. Your one of those company geeks that will fly broken junk, work an eighteen hour day, piss and moan about the company and then blow in anyone who wants union representation. I know your type, and you'd probably bend over for Uncle Kenny anytime he'd ask.
Save the smartass remarks, I'll read about you in "Aftermath"
Regards,
KiddDynomite
P.S. Jetdog, Western New York is familiar!
First, I dont work at Flight Options as I already stated numerous times above
Second, if you read my posts instead of picking personal fights youll see I never advocated flying unairworthy airplanes, busting unions, or working over duty times. All the things you allege I said are untrue.
If you really read my posts you would see my comments as well as that of the other poster's support unions with respect to maintenance as they offer support of a pilot who doesnt want to fly "broken junk" as you put it
As far as working over duty time I dont see that any where on this thread
