Basil
- Aug 10, 2007
Where did you see that? The only requirement is that you have your PFD/HSI set with a CDI needle (not a Map/course track) to varify any deviation. If that's what you ment then excuse me.
I was refering to some RNAV DP's out of KLAS back a few years ago when they were named RNAV B (vs RNAV 1). I don't recall the exact terminology on the charts, but I believed that it covered manually setting CDI sensitivity to 1.0nm and using F/D or A/P.
I'll let someone with a greater command of grammer decode AC 90-100A:
(9) Pilots must use a lateral deviation indicator (or equivalent navigation map display), flight director and/or autopilot in lateral navigation mode on RNAV 1 routes.
