Flight, already late, diverted to pick up Bush twins
OtterFO said:
You are correct, the gravel strip is now closed, but still lit. They turned the section directly across from the MCC into a helo pad, mostly because the medics are based in the MCC now and it makes transports easier.
Back to the origional subject, Re-routes are not uncommon.
You flying the Otter up North? Sure was surprised to see snow so early in ANC! Coming in last night it was snowing up high and stopped around 1500'.
