Try CFR49 119.3 Definition:
Domestic operation means any scheduled operation conducted by any person operating any airplane described in paragraph (1) of this definition at locations described in paragraph (2) of this definition:
(1) Airplanes:
(i) Turbojet-powered airplanes;
(ii) Airplanes having a passenger-seat configuration of more than 9 passenger seats, excluding each crewmember seat; or
(iii) Airplanes having a payload capacity of more than 7,500 pounds.
(2) Locations:
(i) Between any points within the 48 contiguous States of the United States or the District of Columbia; or
(ii) Operations solely within the 48 contiguous States of the United States or the District of Columbia; or
(iii) Operations entirely within any State, territory, or possession of the United States; or
(iv) When specifically authorized by the Administrator, operations between any point within the 48 contiguous States of the United States or the District of Columbia and any specifically authorized point located outside the 48 contiguous States of the United States or the District of Columbia.
Flag operation means any scheduled operation conducted by any person operating any airplane described in paragraph (1) of this definition at the locations described in paragraph (2) of this definition:
(1) Airplanes:
(2) Locations:
(i) Between any point within the State of Alaska or the State of Hawaii or any territory or possession of the United States and any point outside the State of Alaska or the State of Hawaii or any territory or possession of the United States, respectively; or
(ii) Between any point within the 48 contiguous States of the United States or the District of Columbia and any point outside the 48 contiguous States of the United States and the District of Columbia.
(iii) Between any point outside the U.S. and another point outside the U.S.
(1) Airplanes:
(2) Locations:
Empty weight means the weight of the airframe, engines, propellers, rotors, and fixed equipment. Empty weight excludes the weight of the crew and payload, but includes the weight of all fixed ballast, unusable fuel supply, undrainable oil, total quantity of engine coolant, and total quantity of hydraulic fluid.
(1) Airplanes:
(2) Locations:
Supplemental operation means any common carriage operation for compensation or hire conducted with any airplane described in paragraph (1) of this definition that is a type of operation described in paragraph (2) of this definition:
(1) Airplanes:
(i) Airplanes having a passenger-seat configuration of more than 30 seats, excluding each crewmember seat;
(ii) Airplanes having a payload capacity of more than 7,500 pounds; or
(iii) Each propeller-powered airplane having a passenger-seat configuration of more than 9 seats and less than 31 seats, excluding each crewmember seat, that is also used in domestic or flag operations and that is so listed in the operations specifications as required by §119.49(a)(4) for those operations; or
(iv) Each turbojet powered airplane having a passenger seat configuration of 1 or more and less than 31 seats, excluding each crewmember seat, that is also used in domestic or flag operations and that is so listed in the operations specifications as required by §119.49(a)(4) for those operations.
(2) Types of operation:
(i) Operations for which the departure time, departure location, and arrival location are specifically negotiated with the customer or the customer's representative;
(ii) All-cargo operations; or
(iii) Passenger-carrying public charter operations conducted under part 380 of this title.
