ATA73Pilot
- Sep 18, 2002
This is correct if you take the written results by the FSDO and get an extention. It is my understanding that if you do not stop by the FSDO before the expiration date, then it is expired and you must retake the test. I have never seen anything written about that. Does anyone have the reference?hoya saxa said:While it is legally "current" per FAR's if you've been continuously employed by a 121 carrier, they still require the test to have been taken within the last 24 months. The only exception would be if you have an actual FE certificate.
Jeff Helgeson said:This is correct if you take the written results by the FSDO and get an extention. It is my understanding that if you do not stop by the FSDO before the expiration date, then it is expired and you must retake the test. I have never seen anything written about that. Does anyone have the reference?
