Part Two
To become a good crop duster pilot required that you accurately fly the airplane to evenly apply the chemicals over the field being treated. We really had to be careful with our flying when applying fertilizers in early spring as any error was there for all to see as the crop started growing. This was achieved by starting on one side of the field maintaining a constant height, airspeed and track over the crop. Just prior to reaching the end of your run full power was applied, and at the last moment the spray booms were shut off and at the same time a forty-five degree climb was initiated. As soon as you were clear of obstructions a turn right or left was made using forty five to sixty degrees of bank. After approximately three seconds a very quick turn in the opposite direction was entered until a complete one hundred and eighty degree change of direction had been completed. If done properly you were now lined up exactly forty-five feet right or left of the track you had just flown down the field.
From that point a forty-five degree dive was entered and with the use of power recovery to level flight was made at the exact height above the crop and the exact airspeed required for the next run down the field in the opposite direction to your last pass. Speed was maintained from that point by reducing power.
To finish the course and be one of the three finally hired was really hard to believe. To be paid to do this was beyond belief. When the season began we were each assigned an airplane, a crash helmet, a tent and sleeping bag and sent off to set up what was to be our summer home on some farmers field. Mine was near Langdon just a few miles from lake Erie.
Last year I tried without success to find the field where my Cub and I spent a lot of that first summer. Time and change linked with my memory of its location being from flying into it rather than driving to it worked against me and I was unable to find it. Remembering it however is easy, how could one forget crawling out of my tent just before sunrise to mix the chemicals? Then pump it into the spray tank and hand start the cub. Then to be in the air just as it was getting light enough to see safely and get in as many acres as possible before the wind came up and shut down our flying until evening. Then with luck the wind would go down enough to allow us to resume work before darkness would shut us down for the day. The company had a very good method for assuring we would spray the correct field.
Each new job was given to us by the salesman who after selling the farmer drew a map for the pilots with the location of the farm and each building and its color plus all the different crops were written on the map drawn to scale. As well as the buildings all trees, fences and power lines were drawn to scale. It was very easy for us to find and positively identify our field to be sprayed and I can not remember us making any errors in that regard.
Sadly there were to many flying errors made and during the first three years that I crop-dusted eight pilots died in this very demanding type of flying in our area. Most of the accidents were due to stalling in turns or hitting power lines, fences or trees.
One new pilot who had only been with us for two weeks died while doing a low level stall turn and spinning in, he was just to low to recover from the loss of control. He had been on his way back from a spraying mission when he decided to put on an airshow at the farm of his girlfriend of the moment. This particular accident was to be the last for a long time as those of us who were flying for the different companies in that area had by that time figured out what the limits were that we could not go beyond.
Even though there were a lot of accidents in the early years they at least gave the industry the motivation to keep improving on flying safety, which made a great difference in the frequency of pilot error accidents. Agricultural flying has improved in other areas as well especially in the use of toxic chemicals.
In 1961 Rachel Carson wrote a book called "The silent spring. " This book was the beginning of public awareness to the danger of the wide area spraying of chemicals especially the use of D.D.T. to control Mosquitoes and black flies.
For years all over the world we had been using this chemical not really aware that it had a very long-term residual life. When Rachels book pointed out that D.D.T. had began to build up in the food chain in nature, she also showed that as a result many of the birds and other species were in danger of being wiped out due to D.D.T. Her book became a best seller and we in the aerial application business were worried that it would drastically affect our business, and it did.
The government agency in Ontario that regulated pesticides and their use called a series of meetings with the industry. From these meetings new laws were passed requiring us to attend Guelph agricultural college and receive a diploma in toxicology and entomology. I attended these classes and in the spring of 1962 passed the exams and received Pest Control License Class 3 - Aerial Applicator.
My license number was 001. Now if nothing else I can say that I may not have been the best but I was the first. Without doubt the knowledge and understanding of the relationship of these chemicals to the environment more than made up for all the work that went into getting the license. From that point on the industry went to great length to find and use chemicals less toxic to our animal life and also to humans.
It would be easy to just keep right on writing about aerial application and all the exciting and sometimes boring experiences we had, however I will sum it all up with the observation that crop dusting was not only my first flying job it was without doubt the best. I flew seven seasons' crop dusting and I often think of someday giving it another go, at least for a short time.
