Falcon 50EX Engine Failure at V1 Scenario
LegacyDriver
Moving Target
This is one that I have always thought would be the ultimate "Oh Shiite!" moment but maybe I haven't considered it enough.
- Max Weight Takeoff Slats + 20 with a Balanced Field
- Airplane hits a flock of geese at V1 and blows two engines out (you pick 'em as it doesn't matter to me)
From what I am repeatedly told there is absolutely no way the airplane will take you any further than the crash site under these conditions.
Is this true? If it isn't true what do you do?
Worse, if it *IS* true, what would you do?
Do you try to accelerate and clean up in ground effect on one engine or clamp on the brakes and dribble off the end at a pretty good clip?
The two-engines-inop go-around requires you make the decision at 1500' or 1000' AGL (I forgot already, sorry--brain dumping Falcon info as fast as I can and replacing it with Legacy knowledge--yeah baby!) so it seems to me there's no way to make this scenario work.
I'd love to hear from the 50 experts on this one.
Just for giggles:
Lets say your flying a $hit-hot Legacy at Max Gross weight on a BF.....and you hit a flock of whatever and blows both engines....what you going to do?
In either case (50 or Legacy) the end result will be a fast deceleration - do you want that closer to the airport or farther?
Technically if it's at V1 and you’re on a BFL you should be able to stop before the end........good luck!!
It's really an imperical question: You will react 3-5 seconds after you know all your options.....which leaves you about 5-7 seconds before you start to leave the runway......if you think your going to start thinking about cleaning up.....blah.....blah.....blah.....it's a joke. Your already on the worse side of the power-cure. The whole reason the 50 checklist has you make the decision 1000AGL is so you can clean-up and accelerate GOING DOWNHILL....if you think this joker is going to fly trying to take-off........
YOU ARE COMING TO REST OFF THE AIRPORT.....PRAY THAT YOU AND YOUR PASSENGERS LIVE.
Crazy to go flying with that scenario.
Your chances staying on the ground, in control and braking, and going off the end are MUCH better than going off the end with an out of control plane that has some altitude and is MOST certainly coming back to the ground very soon. At least keeping it on the ground can most likely keep you in the airport boundaries, instead of hitting houses or other structures after trying to struggle with it for 10 seconds.
My take-off briefing for years has always been, "before V1 all the major stuff (engine failure, fire, unrecoverable loss of directional control, T/R deployment or obstruction on the runway), we stop.
BUT............
"after V1 we'll keep it on the ground if I decide the plane will not fly"
Sometimes co-pilots have looked at me like, "WHAT?"
Have to explain odds to them. One impact is better than two impacts.
***I've never flown the F 50, but I have flown the B-747 for 820 hours and that was in almost everyones take-off briefing.***
I did this in the sim taking off from JFK. I got airborne to about 25 feet AGL. It will stay there all day as long as you don't try to turn or change configurations. I suppose I could have eventually burned off enough gas to be able to return to the airport and land, as long as I did run into something first? Or I could have landed straight ahead on the 10,000 ft runway with room to spare, but I wanted to see what it would do.
With a Legacy, I guess I would have crashed into the bay?
Obviously in a twin you're dead. I just wondered if having that third motor would do anything other than keep you alive a little bit longer before crashing.
Also, how long until you melt the engine at max power? At some point you have to retard that thrust lever even at 25 feet. How much fuel will you have burned by then and would it be enough?
In a Legacy my decision is made for me. I try to stop.
That third engine leaves you with something to decide though and by the time you realize you've lost two you may have committed to a takeoff... Bad scenario.
Just for giggles:
That's the beauty of a twin--your decision is already made for you. Having that third engine can complicate things if you act thinking you've only lost one engine, rotate, and try to fly the V1 Engine Failure Profile without realizing you've really lost two engines...
But if you only lose one engine the PNF will be watching the airspeed continue to increase. If you lose two engines the airspeed will immediately stop, then start to decrease.
I've done, for giggles, in the sim, lost two engines at MGTOW in the B747 and airspeed stops immediately and starts falling off in 1 second. If it ever were to happen in real life, you're gonna keep it on the ground no matter where you are in the take-off run, because it WILL NOT fly. Even if you just rotated, slam it back onto the remaining runway and hold on.
I dont really know what would have happened. I just asked to do it at the end of recurrent training to see what would happen. The aircraft was at max gross weight and I don't remember the temp. I was just happy to know that it would fly. I guess eventually you would hit something at that altitude before you got light enough to climb higher, turn or bring up the flaps?
Who cares about melting the engine in this scenario?
Well someone better. I don't think it is going to run indefinitely at max power and then you are coming down wherever you happen to be.
If you are over the water at JFK at 25' then maybe ditching is your best option or if you are out in Midland, TX (or someplace like that) find a field and belly it in.
FWIW, about the only way you're going to get a 50 to accelerate on one engine is in a descent. That's the reason that we're told that once we get below 1000' AGL on one engine we're committed to land. The assumption that in case of a go around you're going to give up 500' of altitude in order to accelerate to climb speed. That gives you a 500' buffer - not a lot. I guess that if you were able to head out across the water in ground effect you might be able to get the speed to build up to the point where you could get a climb going. Bottom line, it's going to take a bunch of luck and some pretty fancy flying.
Buy a lotto ticket. Same chances. Did you do a NTSB search? Never happened. Anything could happen. What if your landing gear fell off when you rotated? Find a real problem.
Nothing ever happened until the first time.
If you seriously believe this scenario is not possible (if unlikely) then you're delusional. But that's beside the point. It is a question that I wanted to ask. If you would like to answer the question please do. The above contributed nothing to this thread. Thanks.
LD, you asked a valid question although from a probability point of view it ranks right up there with me winning back to back mega lottos. Sure, there is a chance but I'm not going to lose any sleep over it and I'm a pretty light sleeper.
Back when I did my DA50 initial the groundschool instructer answered the question this way...
"If you lose one engine, you're not having a very good day. If you ever lose two engines you will lose the third - you're dealing with saboutage."
That pretty much sums it up. The loss of any one engine is as close to a non-event as you can have. It's not even considered an emergency and the checklists for it are in the Abnormal sections. If you lose an engine, then another, shortly after departure then somebody's been messing with something and you're going to lose the 3rd engine. Whatever happens after that isn't going to be Garrett's fault.
LS
How's the ex-wife?
It could happen with birds. Other airplanes have lost two engines from birds on take off, a falcon 20 not to long ago.
I think most jets are like that these days.
The EMB is also an Abnormal for engine failure. (I know at FSI KTEB they were so proud of the fact that an engine failure wasn't an emergency, which always puzzled me a little. LOL! ) :) Maybe the 50 was the first corporate jet like that, although I would think a Jetstar would be the same way.
Since you said please :beer:
NTSB Identification: IAD05LA129.
The docket is stored in the Docket Management System (DMS). Please contact Records Management Division
Nonscheduled 14 CFR Part 135: Air Taxi & Commuter
Accident occurred Thursday, September 01, 2005 in Lorain, OH
Probable Cause Approval Date: 8/29/2006
Aircraft: Dassault/Sud Falcon 20D, registration: N821AA
Injuries: 1 Minor, 1 Uninjured.
The small, twin-engine business jet was about 15 feet above the runway on takeoff, when a flock of birds from both sides of the runway flew up in front of the airplane. The number two engine "surged," and "loud reports" were heard before the copilot noted a complete loss of power on the number two engine instruments. The airplane climbed for about 10 seconds, before the copilot observed the gas producer (N1) gauge on the number one engine decay through 50 percent. The stall warning horn sounded, and the pilot adjusted the flight controls for landing. The airplane contacted the runway with the landing gear retracted, overran the runway, struck a fence, crossed a road, and came to rest in a cornfield about 1,000 feet beyond the initial point of ground contact. Post accident examination of both engines revealed evidence and damage consistent with multiple bird ingestion. The National Transportation Safety Board determines the probable cause(s) of this accident as follows:
The ingestion of multiple birds in each engine at takeoff, which resulted in a complete loss of engine power.
My T/O briefing has always included "Post V1 and the aircraft is capable of flight, we'll continue and treat it as an inflight emergency...blah,blah,blah" If the plane ain't gonna fly, your decision's been made for you. Land it straight ahead and hang on for dear life!
