I said "crossing the pond" since when is that not international flying?fokkerjet said:Now it has to be international..........
501261 said:Lufthansa flight 408 (EDDL-EWR) and 409 (EWR-EDDL) are operated by Privatair on an Airbus A319.
With an N number? All kidding aside I do not know enough about the JAA ETOPS cert requirements to speak intelligently on a Swiss registered aircraft (private air) flying contract for a JAA country. Does it have a RAT/HMU back up?
People the point is the 737 was never intended to be an international aircraft (like the 2000). When Boeing, Airbus, Gulfstram and Bombardier sit down to draw an international aircraft it ALWAYS has redundant systems, especially electrical systems.
Aloha flies the 737-700 from SNA to HNL.
Apparently Boeing, Airbus, Gulfstream, Bombardier and even Dasault (with the 3 engine aircraft) feel that it is a good idea
Yes, I'm perfectly comfortable flying the 2000 or soon the 2000EX across the pond. You're telling me that I can have a complete electrical failure which means I have to lose two generators and an APU generator and, in the case of the EX, drain two batteries to get in that situation. Tell me, does your ABEX system ever fail? Is it possible it could fail? You're telling me just by having that system or a RAT somehow mystically gives you green light to go international? The probablility of losing all electrical and RAT/ABEX are remote...more remote than losing three generators and two batteries?I am missing your point, are you saying that you would feel comfortable flying across the pond in an aircraft without a back up electrical system? Because the last time I check there were NO international commercial flights in any airframes that do not have one.
"The Next-Generation 737 airplanes are derivatives of the Classic 737s, and are powered by derivatives of the highly reliable CFM56 engines," said Hayhurst.
Besides one or two more engines? What are you thinking. An additional engine is one heck of a back up. Why would a 4 engine aircraft with 4 generators need a RAt/HMU? Most Boeings (at least the ones I am familiar with 757/767/777) and Airbus's(330, with the 320 having an identical cockpit I would venture to guess that it is eaisly retrofited) have RAT's.What was your point by asking what the back up is on a 747?fokkerjet said:I would think that anytime you have to be ETOPS certified, it qualifies..........Hawaii is not international, but 3 or 4 hours out over the Pacific makes it just as "international" for this discussion, as "over the pond".
Etops is not part of the discussion, first off who is flying an ETOPS Falcon, Gulfstream or Bombardier? No One
Secondly the only reason why the 737 was able to get etops was that they were able to prove to the FAA that the CFM's have a tremendously high dispatch relialbility rate. From the Boeing press release:
"high dispatch reliability, a fleet service history of 500,000 in-flight hours in just 20 months and high engine reliability rate." see above post for full quote.
Which corporate aircraft will ever post the kind of flight hours the 737 does? Not one, certianly not the F2000
Since when does part 91 need ETOPS certification?
So why do you keep bringing ETOPS up? Once again, ETOPS is a lot more involved then just adding a RAT or an HMU
You got something against taking the F2000 to Alaska?
Nothing at all, and I never sais anything to the contrary. Once North & Souh are fine, Latin America is fine. But the 2000 was NEVER designed to be a long distance over water aircraft.
BTW, what happens if you lose the right engine, or left hydraulic system on your airplane? What happens to your backup? (It's been awhile, I think I have the correct sides!)
What's the "back up" on the B727, 747, 757, DC8 and L1011; besides one or two more engines?
So you are the ONE guy who had that happen on the DA-2000. We talked about the ONLY incident that a Falcon 2000 had a complete loss of both hydraulic pressures while I was at initial training at FSI. That must have been interesting.G4G5 said:I have had complete fluid loss's in both the G4 and the f2000. Neither was what I would consider to be a major problem.
Not a total fluid loss. I had a permaswage fitting on the #1 Engine hyd pump come apart, an instanious loss of system press and fluid. I still had the other system. Sorry for the confusion.G100driver said:So you are the ONE guy who had that happen on the DA-2000. We talked about the ONLY incident that a Falcon 2000 had a complete loss of both hydraulic pressures while I was at initial training at FSI. That must have been interesting.
While I don't fly the 604 there are some limitations with the RAT on the CL65 which I believe is the same. There is a speed limitation of 250 KIAS expect for the purpose of starting a engine after a dual engine flame out.Mudworm said:What is the performance penalty for RAT operations? We looked at that machine some years back and If I remember rightly if the RAT deploys (intentional or not) there are certain operational limitations and a performance penalties that could make you swim the last few metersif it happens at the wrong time and place (ie ETP on a KATL-EINN trip). I think that is why we are in a GIV today.
My question is more what the increased drag resulting from RAT deployment costs you in fuel burn? Me thinks that in the case of a long leg ending with a significant overwater portion (ie Orlando - Shannon) if one were to have a RAT deploy at the ETP one may not have the fuel required to press on or divert to your ETP alternate.CarjCapt said:While I don't fly the 604 there are some limitations with the RAT on the CL65 which I believe is the same. There is a speed limitation of 250 KIAS expect for the purpose of starting a engine after a dual engine flame out.
It does make some noise and if you don't make a normal landing and bang it on the RAT may swing up an smack the side of the fuselage.
I've tested it twice and it will wake you up.
The GV/G500/G550 has three 45 KVA Independent Drive Generators any one of which will provide power for 150% of the jet's average electrical load. The third IDG is located on the APU which can be started at FL430, is guaranteed to start at FL390, and will provide 100% power (45kva) to FL450. I can vouch for the fact that the APU will run at FL510 because I have forgotten to shut it down after the APU start test on the production card and flown it to that altitude.fokkerjet said:...the only difference between electrical systems between the 2000 and 900, is that my third generator on the 2000 is part-time. If I lose one generator, I will load-shed until I'm able to start the APU (about the same procedure as the Gulfstream now, from what I understand). . .
