Flat Spot
Registered Boozer
- Aug 27, 2004
You are not an arse if you are correct .... only if you make foolhardy statements.2000flyer said:You G-Wiz guys really me up on the "international use" issue. I'm sure the design team at Dassault said "you know, lets design a 3800nm airplane but make sure everyone knows not to fly it over water! It will be the perfect aircraft for flying from TEB to SFO or EGGW to LFPB but should never NEVER NEVER be flown from EINN to KBGR!"
Excuse my french, but give me a f'n break! Are those life rafts for crossing Lake Michigan? Tell the Hawker 800 guys I had lunch with two weeks ago who fly 75% international. Tell that to the Citation X crews who fly international. Hell, tell it to Charles as he set out for Paris in a piston single!
I've flown international in a straight 2000 several times. No problem. We plan for every contingency, just like you do in your Gulfstream. I'm curious, does the BBJ have a RAM to help out in the event of an engine failure? I'm just asking because I'm curious. Does the G2/3/4/5?
I do know guys are flight planning the EX at 3000# the first hour. 604 crews I've spoke with plan 4000 the first hour. A crew I know in the Rockies area say to make Europe non-stop they have to start out at...gulp...M0.72. They get to London with minimal reserves...but HEY!....they had the RAM just in case!
I've only had our 2000 to FL470 twice and G4G5 is correct, it's really not worth the effort. The EX, however, should be better with the extra thrust.
As for the 2000EX, I'll let you know in a couple months. Thats if I live through the three international flights we have planned!
I apologize for being such an arse on the international issue. To each their own. If you want to spend more for a 604 that will give you about 200nm more range over an EX, burn more fuel and flies slower/lower...oh yeah...and has a RAM, go for it. Dassault builds an excellent product that pilot's, for several years now, have flown over water with no problems that a RAM would have provided relief for.
Kindest Regards,
2000Flyer
Gulfstream 200 said:I dont think anyone implied that one COULD NOT take a 2000 across the Atlantic.
But as far as very often, or as in the case of that hawker 800 crew that does 75% intl - one would really have to question the logic behind their aircraft selection. Anyone in thier right mind would rather be First Class on BA or Virgin than cramped into a Hawker as they swing through Gander and/or Kef...torture...
A 2000 is not an International airplane. Once a year or so to London - fine - but frequent crossing - nah.
3 engines and/or a RAT is surely something to think about.
Flat Spot said:My objective in asking the question, was not to start an arguement, but to get peoples honest thoughts on these aircraft. Our Dept may be faced with the prospect of selecting one of these aircraft for our domestic op's. We have received info from the manufactures as well as independent sources. However I believe that info gathered from all sources can benefit us in making a good selection. So thank you for any insights you may have.
2000flyer said:My guess, since this company flying the Hawker started off in an old 600 and now have an 800XP fly it because the like it and can afford it.
Let me ask you this...if a 2000 is good for London "once a year or so" why not 5, 6, or 7 times? Are we increasing our odds for droom by doing so? With that argument, am I throwing caution to the wind on every flight, be it international or domestic?
Yes, the company I work for could go out tomorrow and buy a 900EX. But in our situation flying 2-4 international trips a year, a 900EX would be overkill for the other 98% of our flying in the U.S. So, for another $10M we've now outsized our needs. I can't count on both hands the number of company's I personally know of who ran out and bought the biggest and badest, even if it was a BE350, and within a year there was no more flight department. So, we make due with what we have. Now, personally I feel a 3800nm aircraft seems reasonable to take international, wouldn't you?
2000Flyer
I would ask what causes pain to your CFO. Is it the cost of capital or the cost of operation? The 2000EX has lower DOC's but costs more than a 604 (especially if you are looking at used 604's).Flat Spot said:My objective in asking the question, was not to start an arguement, but to get peoples honest thoughts on these aircraft. Our Dept may be faced with the prospect of selecting one of these aircraft for our domestic op's. We have received info from the manufactures as well as independent sources. However I believe that info gathered from all sources can benefit us in making a good selection. So thank you for any insights you may have.
2000flyer said:You G-Wiz guys really crack me up on the "international use" issue. I'm sure the design team at Dassault said "you know, lets design a 3800nm airplane but make sure everyone knows not to fly it over water! It will be the perfect aircraft for flying from TEB to SFO or EGGW to LFPB but should never NEVER NEVER be flown from EINN to KBGR!"
If the FAA won't let the traveling public cross the pond on an aircraft without a back up system what does that tell you? No 121 carrier crosses the pond without one.
Raymond Orteig had offered a $25,000 prize to do it, what do you get today if you try something that stupid? He offered that 25k in 1919, what is that in 2004 dollars? People will do dumb things for that much money, I wonder what the FAA would have said? You know the same guys that mandate the life rafts. You may want to look at the life raft FARs.
The G4/5 (never having flown the 2/3) have an "Abex system" it is a hydraulic pump that has a generator connected to it. Simply put if you have hyd pressure, you have electrics. It also has TWO batteries and in some cases up to 7 Ebats (most have 4).
The 2000 is an excellent aircraft but not an international aircraft. This came directly from the words of the Dassualt sales man who sold the company I was working for their aircraft. He asked how the aircraft was and I said, " awesome on fuel, I just did HPN- SJC on under 10,000#, half the burn of my G4" Then I asked him, why do the low fuel lights come on with 1000# per side, how can you expect to go any distance and not see the lights (aircraft holds 12,000#) He said, "Dassault did not want to build an aircraft that competed with the THREE engine aircraft for international flying, it was not their intent to take market share away from their own product, if you want to do that buy a 50 or a 900"
When they built the 2000 that was correct. Dassault knew that it had to compete with the the G-200 CL-604 and the to some extent the the G-IV, hence the development of the 2000EX. . One does not build a 3800nm range airplane to fly from TEB to the West Coast.G4G5 said:The 2000 is an excellent aircraft but not an international aircraft. This came directly from the words of the Dassualt sales man who sold the company I was working for their aircraft. He asked how the aircraft was and I said, " awesome on fuel, I just did HPN- SJC on under 10,000#, half the burn of my G4" Then I asked him, why do the low fuel lights come on with 1000# per side, how can you expect to go any distance and not see the lights (aircraft holds 12,000#) He said, "Dassault did not want to build an aircraft that competed with the THREE engine aircraft for international flying, it was not their intent to take market share away from their own product, if you want to do that buy a 50 or a 900"
fokkerjet said:So I guess you're implying that Gulfstreams are ETOPS ready?
QUOTE]
It has nothing to do with ETOPS. Name me one part 121 carrier that crosses the Pond with an aircraft that does not have some form of a back up electrical system. If the FAA won't let you and I purchase a ticket on an aircraft without one what does that tell you?
fokkerjet said:Actually, I'd be a little more worried about fire......in the galley, cabin or in baggage compartment. A couple of fire extingushiers just aren't going to do the job.
