fake military pilot?
  • Thread starter Thread starter bell47
  • Watchers Watchers 26
How the Viper is better at CAS than a E model is beyond me, you will have to explain that one.
Easy to explain. Carrying bombs doesn't count, putting them on target does. Vipers with pods, datalink, etc. are the platform of choice, because they get the job done most effectively. The 15 needs the "X" more time and "Y" more bombs because it take longer to find the target and get the bombs on it. Put pods, datalink and HMS from a Viper on the 15E and you might have something.
The 15s sitting on the ramp didn't keep the Iraqis from flying. The mission they accomplished by sitting on the ramp was saving fuel for the Vipers. The airplanes that were flying kept the Iraqis on the ground.
I see your point that the Viper might better at CAS than an E model. However, I'm a light gray driver and can't speak with the certainty that a E model guy / gal would. Yes, SADL is built for doing CAS. Which blocks of Vipers actually have HMS?
However, if you are going to go deep and hit targets that will bring a country to it's knees you would want your force equipped with Link 16 (standard equipment on Eagles). You are also not going to be doing CAS with out air superiority, something gained by Eagles in GW2 regardless of whether they were airborne or not.
Your last comment about Eagles on the ramp is pride overriding logic. The IAF stayed put due to lessons learned form GW1. The Eagles stopped flying in GW2 once the air fields were shut down. The Eagles accomplished their mission by presence.
History is doomed to be repeated by those who don't know it.
Block 40-50 F-16s have link 16 and HMS (if they don't have it yet, they are being modded). Block 25-30s can get on the Link with SADL through a Gateway.
Naaaaaaa...Don't think so.
I don't think the grunt on the ground would ask for vipers or E's unless that was all that was available. I think if the threat allowed and you asked the grunts on the ground what they would really want for CAS, the answer would probably be the AC-130 followed by the A-10. This also from a former FAC/ALO.
Upgraded Vipers
All platforms have areas where they excel. The Viper community has learned a lot about CAS over the past several years and is top notch.
The 388 FW has been the first to field the full-up Blk 40/CCIP/HMCS/SniperXR jet in OIF. The 4th is doing some stellar work with the new toys - including the Laser Mav borrowed from the Navy. We continually work to get better at this mission!
Why does the Eagle need two engines?
To overcome the frontal area required to contain the craniums that fly them. (Sorry Biff, couldn't resist).
Actually dude it's a compliment to the guys that fly it. It's not like we go lift vector on and pull, then throttle as required to fix all errors...
The Lightning AT pod on a Block 30 is the perfect CAS machine for the conflict we are in. The combination is so good, the Army requires there always be one squadron of guard/reserve block 30s in country. It's a testament to what can be done when fighter pilots can lead in the development of an airframe and be supported by their command. It's a great thing about the guard/reserve--they cut through the crap and get the job done.
I understand completely how much better the Guard / Reserves are about buying / equipping the troops. I did 9 years on AD and the last 11 in the Guard. We do better training by a factor of 5. My particular unit is in the C model transition which should work out good once we get upgraded radars (long over due in the Eagle fleet).
It's amazing how different an organization operates when most everyone can be a day away from quitting. I think total force will end up being total farce, and ruin all the things that make the guard/reserve great. Guys will not want to stick around as TRs without the camaraderie but all the active duty BS.
11111
The most combat effective use of two engines? A two ship of Vipers. (Until they become a legacy airframe.)
Actually GF, it's my Hog.....single ship.
Biff..you and GF are quite entertaining with your "I can do CAS less poorly than you can" pi$$ing contest.
Ask your average grunt on the ground who they want overnoggin when the crap hits the fan, and the overwhelming answer is consistently the "legacy" aircraft that still gets it done.
Biff...talk about taxpayers getting their money's worth....no argument the A-10 has been the most cost-effective CAS killing machine in modern history.
Questions???
ATTACK!!!!
Until we have to push you off the fires net because you're stepping on the JTAC's calls for fire with reports of "personnel on bikes" that look oddly similar to canines (Dogs, for the layman).
I get the " I can't talk about it" alot. He claims he was flying combat in Iraq, and ejected once but couldn't talk about it. I just go along with it, but it really hacks me off to be lied to. He claimes he went to the AF academy, at some point was an avionics tech, flew f-16's, and owns his own business, but flies freight just because it's so much fun.
Sounds like some puke working for Empire that flies a Caravan and says he works for FedEx.
It depends (standard answer)
Sometimes putting metal on target in the minimum time possible is the most important. A-10 wins here.
Sometimes blitzing the target with multiple JDAM/LGBs in a very short time is more important. 2 ship of Vipers (properly equiped) wins here.
Sometimes having a longer presence over-skull with all the gucci toys to dig out the bad guys and (almost) never going winchester is what is important. F-15E wins here.
Having flown all 3, I think I can say that they all have niches where they excel. But for the dude on the ground, I'm pretty sure the A-10 will win a popularity contest every time. That is one singularly-minded killing machine.
Cheers,
-Mongoose
If his story starts, "I was in the Air Force...", then you know he was never in the military.
He was employed by the Federal Freight and Ordance Delivery Service.
To check a poser, ask them some questions regarding their training, if they can't come up with answers off the top of their head they are a fake.
As for me,
MCRD SD, G co, plattoon 2025, SDI Sgt Silva, DI Sgt Gauspel, DI Sgt Rouse, DI Sgt Morgan, DI Sgt Tobais.
MCT at camp Pendelton
A school at NAS Memphis, and Pensacolla
C school at NAS Lemmore (middle of nowehere)
That was 10 years ago.
As for me,
What happened to B and D school?
Questions???
ATTACK!!!!
GoUgly,
Concur! My educating of GF was incomplete.
Biff
If you will look at Biff's planes flown, you will see that at one point in his career, while not dropping the iron, he was a true "minister of death".
Not many Eagle guys can claim they ever got a "Bull" on a TAC check. I got a Form 8 to prove it. Quite a few also have some interesting Gulf War memorabilia... I think Biff speaks as a C-model guy, but with some perspective others may have overlooked.
