I know of no instance when a tanker, AWACS, Compass Call, RJ, U-2 or any other HVAA got bagged when Eagles manned the HVAA CAP
Dude, you're smokin' crack if you think your beagle can out turn a Viper. It has its advantages, but that is NOT one of them. BFM is, sorry to say, exclusive to the Viper in this case. With FULL internal fuel, 2 A-9's, and load of bullets the F-16C Bk 30 BM weighs in at just under 25,000 lbs. Engine puts out 28,000 lbs thrust. At 10k or less I will be able to pull 9G's until I run out of fuel or you die. The latter will most likely occur.If it was ever flown clean (no CFT's) it would rage over any viper including block 50's and 60's.
I'd like to see it when you actually use that TFR at 100 feet. It'll be a cold day in he!! when that happens. The TFR was in some Vipers previous and was deactivated because it wasn't gonna be used.F-15E TFR- 100 ft at 600+ knots, with a free A/A radar.
But not quite what a B-52/B-1 will carry. I'm sorry, but I just don't see the relevance. A Viper has a specific A-G job and does it better than any other fighter. I don't think anyone will sign off on a lone Beagle as opposed to a four ship of Vipers anyway.The air to ground capability is substantial with a max loadout of 81K. That is more iron than a 4 ship of vipers carry.
Dude, last I checked you have the same missles we do, and our limit is not our radar when it comes to A-A employment. And, oh by the way, vipers DO have two ID modes. One currently fielded, and one (better one) on the way VERY SOON.As far as air to air, the APG 70 is second only to the V2. A viper is dead before the "declare" call is made since it can not ID.
I just got back from Maple Flag. The OCA was split 33/33/33 Eagles/Rhinos/Vipers. On FOUR occassions an entire 4 ship of OCA was wiped out on the initial push. All four times they were unaware. Can you guess which aircraft it was ALL FOUR TIMES? Yep, you guessed it - the ultra-high SA, mightier than thou, Sort-to-the-mort, Salami receiving EAGLES!F16 -> One Seat, one airplane, one driver, one engine, any mission, one result = NO SA!!!
AlbieF15 said:Don't measure yourself by the last 350 hour flight lead you gunned
