• NC Software is having a Black Friday Sale Event thru December 4th on Logbook Pro, APDL - Airline Pilot Logbook, Cirrus Elite Binders, and more. Use coupon code BF2020 at checkout to redeem 15% off your purchase. Click here to shop now.
Expired CFI
flyup
Member
Total Time
pay me
Can I renew my expired CFI by adding the CFII rating to my certificate? Do I need an endorsement to take the CFII practical?
No flame about letting my CFI expire please!
landlover
Total Time
5000+
NYCPilot said:
That would work.
not quite, you'd need to take an instructor single engine and instructor instrument (2 checkrides) to get both of them. Once the certificate has expired you are no longer an instructor and need to take all checkrides over assuming you wish to regain them. If you take only the CFII checkride you would only be authorized to instruct IFR students, no PVT or Comm. Yes, you need instruction recieved and be endorsed to take all checrides aside from the ATP. Plus the required knowledge exam.
NYCPilot
Incorporated.
Total Time
.00001
Landlover, you might be right.
I'm thinking that if you get the CFII it renews the CFI - but only if the CFI has not yet expired. Sounds like he needs to do the checkride all over again with the writtens.
Bummer.
flyup
Member
Total Time
pay me
dang man... why did I let that expire?! From the looks of 61.199 it doesn't look like I have to take the written over?
flyup
Member
Total Time
pay me
Also, I remember having to take my initial CFI in a complex aircraft but I can't find anywhere it says that in applicable p61... any insight to this?
landlover
Total Time
5000+
complex requirements for the checkride is in the PTS, Im pretty sure you only need to do the landings and traffic patterns in a complex the rest in a fixed gear if you want.
bugchaser
Member
Total Time
10k+
No writtens required, just a simple checkride in any airplane. At least thats what I have been able to do. Took my last one in a 172 and he reinstated all my instructor certs on the same ride. Find a nice D E and get it done.
banned username 2
Banned
Banned User
Buuuuuzzzzz... Wrong answer... All you need to do is either take a Re-instatement ride in any airplane and it will renew your Certified Flight Instructor Certificate (and ALL the ratings on it: i.e. Instrument, Multi-Engine, etc)... You don't have to take a separate ride for each rating... Also no written tests are required...
61.199 Expired flight instructor certificates and ratings.
(a) Flight instructor certificates. The holder of an expired flight instructor certificate may exchange that certificate for a new certificate with the same ratings by passing a practical test as prescribed in §61.183(h) of this part for one of the ratings listed on the expired flight instructor certificate.
(b) Flight instructor ratings. (1) A flight instructor rating or a limited flight instructor rating on a pilot certificate is no longer valid and may not be exchanged for a similar rating or a flight instructor certificate.
(2) The holder of a flight instructor rating or a limited flight instructor rating on a pilot certificate may be issued a flight instructor certificate with the current ratings, but only if the person passes the required knowledge and practical test prescribed in this subpart for the issuance of the current flight instructor certificate and rating.
http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr&sid=4d253c7a06e92489882ea320948cfcc4&rgn=div8&view=text&node=14:2.0.1.1.2.8.1.10&idno=14
Storm Chaser
Total Time
3000+
Falcon Capt is right....61.199 all you have to do is take the instrument check ride in the single-engine and it will renew your FI.
A Squared
Total Time
11000
I don't think you are correct .. actually you are correct, but you're not answering the correct question. If I understand it, the original poster does not hold a CFII rating on his (expired) certificate, so would have to take the CFI ride to reinstate his CFI.
SkiHerkDrvr
Member
Total Time
4700
A Squared,
I agree with your read of 61.199, but in practice this is applied differently. I was in the same boat a year ago- I had a CFI certificate that had expired 17 years ago and I renewed it by adding a new rating to my expired certificate. In my case I added the MEI and was issued a CFI, airplane single and multi engine. Here is something I pulled off the FAQ page:
Ms. Kathy Minner
Technical Specialist
Aviation Services Department
Aircraft Owners and Pilots Association
421 Aviation Way
Frederick, MD 21701-4798
Dear Ms. Minner:
This is in response to your letter dated February 4, 2000, to the Office of the Chief Counsel, Federal Aviation Administration (FAA), regarding § 61.199(a). Specifically, you are concerned about the reinstatement of expired flight instructor certificates and ratings.
As you point out in your letter, § 61.199(a) provides, in pertinent part, that the holder of an expired flight instructor certificate may exchange that certificate for a new certificate with the same ratings by passing a practical test for one of the ratings listed on the expired flight instructor certificate. (Emphasis added)
You also point out in your letter that the General Aviation Inspector’s Handbook provides, in pertinent part, that the holder of an expired flight instructor certificate may have all ratings on the certificate reinstated by satisfactorily completing a single practical test.
You think the General Aviation Inspector’s Handbook indicates that “any” practical test for a flight instructor certificate or rating would reinstate the expired flight instructor certificate and all the ratings on it. Based on that, you don’t think that the holder of an expired flight instructor certificate is limited to taking a practical for one of the ratings listed on the expired flight instructor certificate to reinstate it as provided for under § 61.199(a). Accordingly, you ask “may a flight instructor reinstate an expired flight instructor certificate by taking any practical test for a flight instructor certificate or rating, or must it be confined to one of those listed on the expired certificate as it seems to state in the regulation.” The answer to this question is discussed below.
§ 61.199(a) applies when the holder of an expired flight instructor certificate only seeks to have that certificate reinstated with the same ratings. It has been the policy of the Flight Standard Services (AFS-800), as articulated in the General Aviation Inspector’s Handbook, to allow the holder of an expired flight instructor certificate who seeks an additional rating to one of those listed on the expired certificate, to reinstate the expired flight instructor certificate, and all the ratings on that expired certificate, by taking, and passing, a practical test for the additional rating sought. As a result, the holder of an expired flight instructor certificate may have that certificate and all of the ratings listed on it reinstated by taking, and passing, any practical test for a flight instructor certificate or rating.
I hope this satisfactorily answers your question.
Sincerely,
/s/ Donald P. Byrne
Assistant Chief Counsel
Regulations Division
