Flyingdutchman
- Jul 29, 2002
Flyingdutchman said:I was having a discussion with a few friends..
Would you during a emerg. dec. (lets say from FL370 to 10.000 feet like that Helios 737 in Greece)
A) Have the A/P fly
or,
B) Fly manual ?
Why A or B ? and what does your company say?
FD
J32driver said:With the A/P on, set 10,000, select IAS mode, power to idle, boards out. Nothing else to do other than deal with the problem. I'd let the autopilot do the work.
Flyingdutchman said:Ok boys.
This is a good and interesting discussion. I would fly manual, unless it's IMC.
What does your company manual say about this? Manual or A/P?
FD
Flyingdutchman said:Is that in the Dash? isn't your max. service ceiling FL 250 anyway?
Keep 'm comming.
(Are you Den based?? getting junior sp*nked a lot last few days??)
DirkkDiggler said:Auto pilot all the way. What happens if you're hand flying and then you both pass out? If the A/P is on and 10,000 is commanded, then at least the aircraft will level out at a breathable altitude and you can wake up before you run out of fuel.
flyer172r said:The only problem I see with that scenario is what happens when the AP levels the plane at 10,000, and nobody is awake to advance the thrust levers?
Spinplate said:Pilot has more control over airplane manually than in AP mode. Loss of cabin press. that drastic is going to be caused by some sort of structural failure somewhere in the plane so in manual mode you would have better control and would be able to make faster pitch/roll changes than AP if it were serious, but its totally situational on what the cause is. Last but not least get ATC to let you know if 10k will even be a good altitude (IMC over Colorado and splat). They'll tell you in a sec the lowest you could go in any direction. Like I said, depends on situation......need to know more on conditions inside and outside of plane.
Spinplate said:I say get the mask on first and make sure you have good O2 flow first, then establish comm with F/O or Capt. for Emergency Descent Procedures. Fly the plane first even if its on AP, but I would prefer to be in manual emergency descent if my O2 was good, why not. Pilot has more control over airplane manually than in AP mode. Loss of cabin press. that drastic is going to be caused by some sort of structural failure somewhere in the plane so in manual mode you would have better control and would be able to make faster pitch/roll changes than AP if it were serious, but its totally situational on what the cause is. Last but not least get ATC to let you know if 10k will even be a good altitude (IMC over Colorado and splat). They'll tell you in a sec the lowest you could go in any direction. Like I said, depends on situation......need to know more on conditions inside and outside of plane.
spinplate said:I wasnt talking about yanking and banking. Im talking about the ability react faster in manual mode than pushing buttons to try and get a desired pitch/speed setting from your FD/AP.
