Well, at Eagle we use N1, not N2 for power settings. Couldn't really give you a number for 220 in level flight. When I went through training, most of the instructors said not to worry too much about memorizing a lot of power settings. The most important one to learn in training is 65%. This will give you 200 knots level (typical speed in the training environment), and will also get you pretty close to your approach speed on an ILS with flaps 45.Knob said:Anybody have any suggestions for thrust settings in the Emb-145?
Speeds such as 220, what would be a target N2? N2 during an ILS? Thanks in advance.
how come then FF is not displayed on the priamary EICAS on quite a few jets?PCL_128 said:Fuel flow is always the best way to set power in any jet.
Yank McCobb said:Have you flown a large number of jets from which you can draw this conclusion?
PCL_128 said:Don't need to, it's just a basic fact of the physics involved. A given FF will always yield the same speed no matter the temp or altitude. N1, N2, etc... all change depending on your alt and temp for a given speed. Do you disagree?
Nova said:Even in a descent, climb, gear down, flaps down in different increments, in a turn, icing, etc....??
aewanabe said:For example in our aforementioned E145, it takes around 1900pph/side to maintain 315 kias in the low-mid teens, whereas that number decreases to 1500-1600 in the mid-twenties (before the mach number becomes limiting, depending on temp).
Huh? Seems like it's been pretty civilized to me!FlamingFUPA said:jeezuz, didn't take long for a thread with usefull suggestions to turn into a pissing contest
Works great for both AS and Alt. After that a little fine tun'n as needed.LAXSaabdude said:Huh? Seems like it's been pretty civilized to me!
And T-Gates, you are right about the trend vectors. One of my instructors taught us to "pinch" the trend vector between the airspeed pointer and the target speed, i.e.as the tip of the trend vector reaches the target speed, gradually add or reduce power so that the tip of the trend vector stays touching the target speed, and the vector shrinks down to nothing as the airspeed pointer reaches the target speed.
Sounds more complicated than it really is, but that's my best explanation.
LAXSaabdude.
