EFB's in Lears
sydeseet
Huge Member
Does anyone have any experience using EFB's in the ever-so-spacious Lear cockpit? I'm trying to balance function, ease of use, and available space before the units arrive.
Thanks!!!!
We use EFB's in both our aircraft. One's a Lear 55. They work well in the Lear, we keep them behind the pilots seats.
I would suggest an outlet in the cockpit to recharge though.
Learjet sent us this..they are working off an arm installed off the map light mount
The FG-4000 features an 866MHz Pentium processor and a display that will adjust for the brightest sunlight or the darkest night without loss of readability or night vision. Installed in the Learjet aircraft, the FG-4000 will allow the display of Jeppesen charts and real time weather when interfaced to the available WSI In-Flight Satellite Weather System.
Although this installation does not constitute approval for paperless operation, it is the first step toward such approval. The customer must coordinate paperless operational approval through the local FSDO. The installation of this system does not guarantee that paperless operation will be approved.
A network STC business case has been approved for the Lear 31, 35, 36, 45, 55, and 60.
The conformity aircraft for each STC must undergo certification flight-testing which will increase the required downtime for this installation. Additional lead-time for certification will also be required for the conformity aircraft.
More info
My understanding is this would be wired into the electrical system and have the WSI weather as an option. We are looking at this for our Learjet 45...also would like the Arinc to serial interface from the FMS for moving map display.
So if we can get a mounting arm, WSI weather, GPS interface and powered by the aircraft it should be pretty nice!
Which EFBs do you have on the way? From what manufacturer? I am also curious as to how many total and how many per plane that is? Not to be too nosy there, but I am embarking on a part time job of selling EFBs for corporate aviation use and I am curious what your order looked like? Thanks!
Efb
Our new 45 will be delivered in 06'. We will spec. it out in Aug 05. So, whatever Learjet has certified at that time is what we will end up with.
What they are advertising now is the previous post.
They equip the aircraft with EFB's from the factory? They should when you consider the price of a new airplane, but I guess I just didn't think about the fact that they would do that.
Option
Well, it should be available shortly for the Learjet's.
I have heard that Cessna has the EFB as a factory option on the Citation XLS
efb's
We've been using EFB's in our Lear45 since we took delivery last September and they've been working great. Since we are part 91 our's did not need to be an approved model. We use the Hewlet Packard tablet PC'S I think the number is 1100C I'm not for sure though. You can check out www.hp.com for pricing, ours ran about 2400.00 a piece, with all the goodies (docking station, keyboard, wireless card, extra plug in adapters). The wireless card works great for when your on the road and need to update the Jeppview and Flitedeck. Takes about 5 min. to update. We do have an outlet installed in the pedestal, so they are plugged in all the time. Otherwise they have about a 3 hr bat. life if left on continuously.
FG-3000 in LJ31a
We use the FG-3000 in our 31a's with no problem. Power socket has been installed for constant 'charging' - and holder is mounted on center console by FO's left knee
I would check out Flight Deck Resources. www.flightdeckresources.com. We have the Skytab 770. I like it a lot. It doesn't have a hard drive or disk drive built in. It's all flash memory. It's not as fast as our laptop, but it's small, light, and has no moving parts. We are running Jeppview Flight Desk and Ultranav and it loads the programs quickly and has a great display. The customer support is great. The battery life is a couple of hours with out the standby battery, with the standby battery it's about 6 hours. External power is suggested. If you have any questions let me know. I like the size the best. Some of the units out there are way to big to be used in a light jet cockpit.
Where do you store that thing in the 31A cockpit? If its permanently mounted, is it in a position where it can be seen and used by both pilots?
While we are on the EFB topic.
Does anyone have an aircraft printer that they can recommend for an EFB. Small, portable, relialble, color..........
We were having a discussion the other day:
Does anyone know what the FAA's interpretation of the EFB is? By interpretation, I mean, does your FISDO still require a paper chart back up to be printed? Is a paper chart even required for an IFR flight?
The Skytap that we use is not permanently mounted. We keep it in a case between the seats. It's really pretty small.
There is an explanation of the FAA's interpretation in Advisory Circular AC 120-76a. It is a pretty easy read and describes the different "classes" of EFB's. We do keep a printer on board a small cannon color printer, and we are printing our destination and alternate airports. We are only using one EFB and I think what we are doing is above and beyond the FAA's requirements. But the Advisory Circular describes in detail what needs to be done. I can send you the AC on PDF if you would like it, let me know.
Thanks fellas!
We are working with FDR and should demo some units soon. I like the size of the 770's but the 800 is a considerably more capable unit. We're leaning towards one of each but the demo may change that. We intend to install an outlet on the back of the console and get the units/installation approved by our FSDO for the occasional 135 flying we do.
Has anyone had any issues with leaving the units in a hot or cold airplane (Phoenix in July or Minneapolis in January for example) overnight?
I hear Jeppesen is as excited as anyone with the technology, can't say I blame them!!!!!
I am currently working on getting 135 approval for EFB in our Challenger 604. We just ordered a Fujitsu FG-4000 unit. Here is what I've been told (seems to differ by FSDO like everything else):
Part 91: Requires an LOA. Need to operate for 6 months with paper charts onboard, then full approval will be granted.
Part 135: Same as Part 91 requirements, but two units are required and Ops Spec A025 will be issued instead of the LOA
By "paper charts onboard" all that you are required to have are charts from the departure, destination, and alternate airports. This means that with the JeppView charts, you can print paper charts (a few pages) and be on your way. It doesn't mean you need a set of NOS or Jepps onboard. I think for 135 they want some sort of printer. We are using the fax machine onboard (which has a serial port) as a printer for the unit. Haven't gotten any true operational experience with the unit yet, still writing procedures and getting approvals.
We are also testing the waters with getting approval for paperless cockpit using an Avidyne EX00 MFD in our King Air. I've talked them into it, but need to have a laptop onboard with all the charts loaded as well. We'll see how it goes. Anyone have any 135 experience with these units that can answer some questions??
At the previous operator I worked for I purchased a HP rechargeable portable printer. It worked great when the need arose to print a chart or two. Take a look at the HP website and you'll find them. I belive there are two models. One wired and one with a nicad battery. If I remember correctly it was around $250.00.
Regards,
S.H.
