Flying Farmer
Member
- Jun 1, 2004
Don't get discouraged by some of the negative posts. The training is very doable if you know how to prepare for a test or a training event. You'll be with other pilots 24/7, so there'll be ample opportunity for group study if that's your thing. Also some good opportunities to throw a few back and enjoy DFW. When I went through, the only guys who had problems were really weak on time (suspect a lot of P51) and very minimal IFR exposure. Good Luck.Flying Farmer said:Anyone know what the training at American Eagle is like? How does it break down, what's the toughest part, the best way to go through it? Appreciate any insight. Thanks!
I thought failing a written or an oral was only a half point (strike)? From what I remember failing a checkride was a full point.MED said:there's a couple of systems test, and if you fail any of them that will count as a strike , and if you have any unsatisfactory performance for any simulator sessions, that will also count as a strike, checkrides are the same thing, so you get 3 strikes your adios. for new hires, after 2nd strike the training manager will talk to you and give you an option to resign or get fired after 3rd strike.
i believe its a full point for new hires, because i remember one of our new hire guy was dismissed after failing a written and an oral.flyby said:I thought failing a written or an oral was only a half point (strike)? From what I remember failing a checkride was a full point.
MED said:i believe its a full point for new hires, because i remember one of our new hire guy was dismissed after failing a written and an oral.
There is no official "3 strike" rule for probationary pilots. The official "3 strike" rule is for "regular" pilots and it is 1/2 point for training and 1 point for checkrides. After your 2nd point you are given the option to return to your previously held position or attempt the 3rd time, if you pass, no problem, if you fail you are fired.Flying Farmer said:What do you mean by 3 strikes? If you fail a checkride (then pass) a written (then pass) then something else - adios amigo? Thanks for the info.
