B6Guy said:As for the Autoland, maybe you haven't seen what the Bus can do, it is amazing how well it can autoland. Maybe you need to check it out. If the wx is so bad that the autoland is not allowed, then make a 'command decision' and go to another airport!
And if you are a G4/G5 guy, you know how easy a turn with a downloaded flight plan is. Piece of cake. You know the workload in a full glass cockpit, what do you do that wears you out so? Memorize the flight manual? Study for a class?? Are you nervous being a pilot. ??
QUOTE]
So let me get this straight. You come back to JFK into that snowstorm everyone is talking about. Airplanes are getting in, but you can't autoland because of let's say the crosswind component. However, the current braking action report / crosswind component appears to be in check in this quickly changing environment. Since you are tired, you will make that "command decision" to divert after a transcontinental flight to one of the other areas of delightful weather that is sure to be just a short hop away from JFK right? When the company asked why you diverted, you will tell them that you were tired and could not autoland even though the weather conditions both did not require and would not permit an autoland. That sounds plausible.
Yeah the Bus autoland is something else. Ever see it screw one up below 50 feet? It isn't a crutch for tired pilots.
