no rubber!!!! keep your feet off, will make it worst
Let it settle on its own (trust the stability of the aircraft).........UNLESS it is a Jetstream 31.....then your altitude is too high anyways......lol.
Wait is a dutch roll one of those special cigarettes you can buy on the streets of Brussells?
Adding a small amount of rudder pressure in one direction will stabilize the oscillation. Descending and increasing the effectiveness of the vertical stabilizer will also help stabilize flight. Its in Aerodynamics for Naval (Navel?) aviatiors. My understanding (and I drive a prop so take it for what its worth) is that all swept wing aircraft will have a tendency to dutch roll. The deeper the sweep, the thinner the air, and the further aft the center of pressure on the wing (ie the faster you go) the worse it gets. Its one of the reasons many aircraft have altitude and mach numbers restrictions with an inoperative autopilot. The performance window for many jets becomes very narrow at the upper altitudes of its performance envelope and dutch roll is one of the causes
I'm not sure, but I think that advice on a 727 will get you killed. I have been told that the 727 is a real dutch roll pig. It will get worse without corrective action.
But the easiest way to exit the situation is to just put the aircraft into a turn.
At Riddle our advanced jet transport aerodynamics professor told us it the above situation ever occurs to just make sure the autopilot is engaged and that would take care of the problem.
Great... Just spit coffee on my keyboard. Thanks!
The corrective action for dutch roll due to yaw-damper loss would be specific for each aircrfat type, but generally...
- Re-engage YD and AP
- If that doesn't work, keep your feet off the rudders
- Correct roll w/ short, brisk aileron inputs
- Descend out of the flight levels.
Doesn't anyone see how this person wrote "no ruBBer"? I mean, seriously, we should require everyone who posts here, to have at least graduated elementary school!
My theory is that he was looking at the Jailbait or Edge540 Avatar while typing.
Classic Freudian Slit.
