Does ATC get pissed???
UnAnswerd
Activity Terminated
You're doing touch & go's at a towered field. From what I've been taught, this is basically the correct call-up on downwind:
"XXX tower, Cherokee 1234 is midfield, downwind, 33, for the option". If we've been told to fly right traffic, that gets added too. I timed myself, it takes a whole 4 seconds to say.
But from what I've heard from others, ATC gets annoyed??? I mean:
"Cherokee 1234 is midfield" ---No sh*t!!!
"Downwind" ---Really??? Next time request the option on climbout!!!
"33" --- Wow!!! That's the runway I told you to use!!!
They claimed saying "Cherokee 1234, for the option", is all you have to say.
What do you think???
I've also heard ATC give pilots some rather long departure instructions, to which is replied with "Yeah, we'll do all that". So I think this may be a fine line....
Depends on the field and if you have been flying the pattern on the same flight. "XXX Tower, Cherokee 1234, right midfield downwind 33, request option" should be plenty, and with a smile you can get it out in 4 seconds.
If it is busy, then you can condense it, especially if you have been in the pattern requesting the same thing repeatedly i.e. "Tower, Cherokee 1234 request option."
Much depends on the amount of traffic. Of course if you switched to cessnas, the call would be even more quick.
Just remember to read back any specific instructions that may be unique. We have a lot of helo operations, and often we are told "Cherokee 123 cleared for immediate takeoff, no turns 'till the west bank of the river." The Tower is expecting us to read back the specifics about "no turns 'till the west bank" or on entering the pattern from the south, since the helo's work south of the field at 600' agl', we are often told to "enter the right downwind at or above 1000', report the right midfield downwind". The Tower is expecting us to repeat back the unique transimission of "at or above 1000'".
Yeah, I've been guilty of failing to read back specific information. They don't like it! The worst is when you switch your call-sign on them!!!
You might consider that the controller's clearance for your T&G *should* include specific runway information. If that is the case, then stating where you are may indeed be wasting breath... however I have never done T&Gs at a towered airport busy enough for them to care.
ALWAYS verify the runway, traffic patterns are very simple as long as effective communication takes place....
They are probably getting annoyed because there is no reason to call on each downwind...they will call YOU and clear you for the option.
Most places I get "report midfield". I will just say "xxx is midfield". They'll give you the rest. I've never given them all that while in the pattern.
The towered fields I fly in don't expect you to report any of your legs - unless of course specifically requested by the controller.
Since it's controlled, and their managing traffic, they will know where your at 99.9% of the time. The only thing you need to worry about flying at a controlled field is making sure you have your landind clearance before getting on short final. Other then that, don't sweat it! When the airports busy with a lot of traffic, it's not good practice to tie up the frequency with unnecessary callouts.
And if they do request it, keep it simple: "Cherokee XXX, right downwind 17."
When I was the only one in the pattern, sometimes i'd get "cleared for the option until further notice"
I always liked the tower call, " cleared to do whatever you want whichever runway you want for a little while, mmm k?"
minitour said:
Not necessarily
No, you should keep your pie-hole shut unless there is some sort of necessary information that needs to be transmitted. Too many pilots get diarrhea of the mouth. If you don't get any specific instructions on how to fly your pattern, or a sequence (i.e. "extend your downwind to follow a 757, caution wake turbulence" or "keep your speed up as long as practical, traffic to follow is a T-38 on a 3 mile final") then you just fly your pattern (quietly) as you normally would.
If you don't have a landing clearance by the time you're about 1/4 mile out, ask or verify. Always read back the landing clearance and runway.
The exception is if the tower has some local procedure that you should follow. For example, if it is SOP to report midfield or "abeam the numbers", then you should do that. How do I know if this airport has a local procedure? You'll be instructed by the tower, usually on the first trip around the pattern.
The important thing to remember is the microphone in the airplane is for important communications necessary to flight safety. It is not for asking for "Wind checks" or asking "any traffic in the area please advise"...I should quit, I feel a rant coming on...
the airport i usually fly in, we usually call tower 10 miles out for inbound(duh thats a given) and we report 2 mile downwind. Usually past midfield they usually "cleared for the option" and we tell them inbound for touch and goes then or when we report for final.
If they need us to extend downwind, they usually tell us before we turn base. They seem to keep up with it usually. Although the biggest plane that comes in is the mesaba S340.
Who cares...sometimes you just have to push back...just on "general principal". You'll know when and where, once you got some time under your belt.
user youll know what im talkin about
i got one of these one time doing my night currency
i got a cleared to land any runaway untill further notice, i was the only one and winds were calm
took off 1L to a kinda left base for 13 s&g to a right downwind for 1R then did a left pattern back to 1L.
some of the guys in the tower are nice to talk to when no one is around
when i did all my night solo stuff in the pattern i would be the only one on freq untill the top of each hour. he'd get hella busy then we'd be back to our convos. someday i wanna meet those people before my reign <sp> in oklahoma is over
...that was exactly my point.
-mini
Really, it depends on the Tower. At my facility, I've got three DBRITEs and a CONRAC in the Tower cab. If the radar's working, I KNOW where you are in the pattern. If I need a report, I'll ask for one, otherwise, there's simply no reason for you to report each downwind or base.
On the other hand, at a small tower without any BRITE or other radar display, it's very easy to loose sight of a white Cherokee in the haze, (especially if you're flying a Boeing sized pattern), and it's a good idea to have the pilot report midfield downwind or each base so you keep situational awareness in the Tower.
Student pilots seldom irritate me if I know they are one. It's the 50 yr old guy in the Baron who still doesn't know how to operate VFR at a controlled field that puts an edge in my voice....
Its also SA for fellow pilots. If I know where you are based on your radio call, helps me find you in a hurry if I need to look for you cause I think you are going to be a conflict.
You mean that's still used as an active runway?!!? :eek: I better stop using that as a taxi-in to the ramp!
Two years of flying in and out of that airport, I've never seen or heard that runway being used! Well, next time I come head to head with you on that runway, I'll wave excitedly, knowing its ole Kream aboard!
Believe ATC when they tell you something. A few years ago I was landing at CSG with a 727-200 full with football player, fans, friends, and cheerleaders. I turned about a 3 mile final to follow a Baron on a mile final. The Baron was getting instruction and the flight instructor was handling the radios. The tower told him that they needed to land and turn off at X intersection traffic on short final. The Baron replied they would try but since they were cleared to land they technically had the whole runway to use. The tower again requested that they land and turn off at X intersection. The Baron replied that they would try but noted that the whole runway was theirs. They landed and missed the intersection, then they proceeded to do a 180 degree turn to taxi back to the intersection. At that point the controller go real mad, I was already spooling up my engines as I knew I was going to have to go around. When the Baron finished the 180 on the runway his windshield was full of a 727 all lights on and a lot of black smoke as I was spooling up for the go around. The Baron taxied off the runway through the ditch and to the nearest taxiway. We all laughed as the controller chewed out the instructor pilot, had they even continued to the end there would have been plenty of room, but no "the runway was all theirs-technically???"
Ha ha, good thing that you were spooling up. I learned real early not to count on a 727 going around from short final without some warning! I always answer the city owns the runway, and I schedule it's use... :D
I also should have added, regarding my original post, that the kind of radar display matters as well. I have an ARTS keyboard associated with every DBRITE. But some small towers just have a small display; some with alphanumerics, (tags), some without. Some will have a keyboard so they can initiate tracks and modify tags, some won't.
what 13/31??
they use it from time to time
i think i used it a couple of times as the only runway
Kream926 said:
what 13/31?? they use it from time to time. i think i used it a couple of times as the only runway
Yea 13/31. I had to actually get out the airport diagram to note what runway that was, cause I had never thought about it before.
That 2,800 ft runway doesn't do us a whole lot of good! We're landing either north or south, stiff crosswind or not!
the planes i fly can land nicely in a 600-700 foot strip;)
