DL/UA International Jumpseat
modesto2
Member
I'm trying to jumpseat out of Buenos Aires, Argentina (EZE) on either DL (ATL) or UA (IAD). Has anyone does this, and is there anything special I need to do? Can anyone with access to DL loads check EZE-ATL on July 31st? Thanks.
I have done it many times. As a general rule, list your self at least 24 hrs before departure and then be at the airport 3 hrs before departure. At UA they're fairly used to jumpseaters, so it should only take a few minutes. If the flight is tight you will have to wait before they issue a priority card and you might have to literally run through customs/security to board the plane. Delta is similar out of EZE but I have only jumpseated once with them.
I cannot access UA loads anymore but maybe someone else can...
Good luck, you will love BA
Ask General Lee, he does that flying for Delta.
