DL mainline to join ASA to EYW!
SPDBRD747400
World's Favourite Airline
DL is not giving up on Key West to AirTran...should be interesting to see DL and Airtran fighting down in EYW!!! I think DL will win this one then go back to only ASA flying the route again. (For those of you that don't know Airtran is planning a 4x weekly ATL-MCO-EYW flight).
Atlanta-Key West
DL 1651 9:55a-12:00p 737-700 Daily
DL 5795 12:05p-2:00p CRJ-700 X67
DL 5330 2:55-4:44p CRJ-700 Daily
DL 5134 6:55p-8:44p CRJ-700 Daily
Key West-Atlanta
DL 5735 7:45a-9:50a CRJ-700 Daily
DL 1402 12:45p-2:50p 737-700 Daily
DL 5195 2:30p-4:35p X67
DL 5594 5:15p-7:15p CRJ-700
http://forums.flightinfo.com/#
Atlanta-Key West
Key West-Atlanta
How many passengers can you put on a 737-700 departing Key West on a 4800 ft. runway? What about when the temperature is high 80's?
Forums indicate:
At Max Gross LDG Wgt--LDG Dist. is about 2600 ft., touching down 1000 ft from beginning of R/W--Dry with MAX Auto Braking
TO--no problem carrying 100 pax + 200 bags + 3.5 hours fuels(20,000lb) at 85 degrees and 4800 ft of Runway
100 paxs at what Delta charges....CASH MONEY BABY!! EYW one of Deltas most profitable routes. The prices DL was charging for EYW, was only a matter of time.
AirTran announced service to EYW. This, I believe is why Mainline is serving Key West. Strictly competition. I know of one commuter out of EYW, so his commute just got easier. Glad for him.
Trojan
Trojan
Airtran is stopping in MCO before going to ATL. They are not nonstop.
Bye Bye--General Lee
There goes Delta, taking our flying again.
Once Airtran enters the route plus all that additional capacity the yield will likely fall precipitously.
Yeah, for about a month. Then they will pull out because the yields are not high enough. You would have thought they would have learned their lesson when American ran them out of West Coast flying in DFW.
Good luck taxiing that 737 without dropping a main in the grass when turning in and out of the ramp along with the narrow taxiways.What about the wing span that could take out a tail on a GA plane sitting there?..Just curious!!
I thought the same thing until your post made me curious enough to look at the numbers. On our CRJ700, the distance from the nose wheel to the mains is 50' 3", while on the 737-700, the distance is only 41' 4". This allows the CRJ to complete a 180 degree turn on a 75' taxiway, while the 737 can do a 180 on a 65' taxiway.
As far as basic dimensions, the 737 is only 4' longer than the CRJ700, but it's wingspan is 41' wider. (Not that you would want to, but you could probably taxi the 737's wingtips above most GA aircraft). So it appears that the 73' would not have any problem.
As a side note, it is interesting to note that the CRJ900 is actually 8 1/2 feet longer than the 737!
The 900 is also only 15 feet shorter than the MD-88. It is a big airplane.
Hence the terms classic(200), stretch(700), heavy(900).
BAAHAA
PBR
PBR,
Now that's funny!
701EV
