Direct To
your_dreamguy
Total Time
3100
When a controller gives you a "Direct To" Are they talking about the airport of to the VOR. For example, a controller says,"Fly direct to LAX." In this case, it wouldn't matter because LAX VOR and the airport are co-located. However, what about when the VOR and destination airport have the same name but are located miles apart. Also, any controllers reading this, please note, it would help pilots out if specify airport or VORs in your clearances.
Flyin2low
Indentured Servant
Total Time
46000
You have to ask the controller. A few years ago they tried to rename VORs that are off-airport but have the same name as the airport. They haven't finished yet.
ALIMBO
Total Time
300
Your instrument rated flying 414's and you don't know this?
Midnight Flyer
Stay Thirsty My Friends
ok, you're flying from SAN to LAX (for example). why would they clear you direct to lax vor as opposed to just klax? it's easier for them to clear you direct to destination as opposed to a vor anyway.
You'll be talkin to approach control when you're something like 35 miles out and you'll be on vectors, so don't worry about it.
ace6453
Total Time
some
I'm sure you deal with this all the time flying your 152 around the pattern just trying to make commercials standards so you can apply go gojet, so please enlighten us.
Lrjtcaptain
Total Time
2000+
I do, and I spell each fix for you too. I can't expect everyone to know it all when you have been issued a reroute. I will not say "Moline VOR" when issuing a route via a DP or a V route or J route, but if you are landing Moline's airport and Get ORD2.SIMMN..MZV..KMLI I will specifiy Simmn direct Moline VOR direct Moline Airport. Definatly avoids any confusion.
Lrjtcaptain
Total Time
2000+
So when you are over Seal Beach and loose your radios you fly to the VOR, and then start an instrument approach from there because the field is IFR and you don't attempt to vector yourself for an ILS.
GogglesPisano
Pawn, in game of life
Total Time
enough
In a situation such as this, I always ask.
I've heard both versions from controllers.
And, as an added bonus, asking doesn't cost a dime!
Amish RakeFight
Registered Loser
Total Time
You're a private pilot with SEL - IFR ratings, yet have ATP listed. :confused:
ALIMBO, I lost a lot of respect for you after you changed your profile to reflect an ATP certificate.
Amish RakeFight
Registered Loser
Total Time
Normally it's the VOR, but if there's any confusion, you ask. Period.
ALIMBO
Total Time
300
Comm asel to be exact.
Total Time
1400
Not necessarily. What if the VOR is not part of your filed flight plan? You could be filed from your last enroute fix, direct to the airport.
This would be good if you are in VMC. What you described is a reroute and your old flight plan is then out the window. The reason for an IFR flight plan is if you loose radio contact you have a plan. So if you are cleared dirct to ABQ VOR then KABQ and you loose communication you can navigate to the VOR in IMC and do the published procedure. However it would be hard to fly direct to that particular airport in IMC.
SSDD
Total Time
17,000
Well if the controller issues a reroute then, as you stated, they'd have to say direct to the vor then the airport. That does not seem to be the case in this situation, besides, there are many cases where there is no published transition from the vor to the approach. Its all predicated on radar vectors.
satpak77
Marriott Platinum Member
Total Time
5000+
if in doubt, ask ATC
with that said, lets look at the FAR's
Sec. 91.181 - Course to be flown.
Unless otherwise authorized by ATC, no person may operate an aircraft within controlled airspace under IFR except as follows:
(a) On a Federal airway, along the centerline of that airway.
(b) On any other route, along the direct course between the navigational aids or fixes defining that route. However, this section does not prohibit maneuvering the aircraft to pass well clear of other air traffic or the maneuvering of the aircraft in VFR conditions to clear the intended flight path both before and during climb or descent.
The Embry Riddle, FAA Inspector checkride answer is the above. "Direct Lima Alpha X-Ray" is not Direct KLAX
If ATC says "cleared direct...." they mean navaid or fix unless otherwise stated. In most cases they will say "VOR" or "Airport" because this question does indeed rear its head again and again
Singlecoil
I don't reMember
Total Time
8760
First of all, if you loose radio contact, you should have tied it tighter. Sorry, couldn't resist.
Well, I would say the reason for an IFR flight plan is to be able to get an IFR clearance. My ATP examiner was an old Air Force guy that never flew commercially. He tore me a new one for filing an IFR flight plan that didn't include an IAF for the destination airport. In this case, that meant a fix on a ten DME arc on the other side of the field from which we were arriving. I kind of said whatever and did what he wanted. Then when flying, ATC had to ask why we had filed like we did, did we really want to go all the way over there, etc.
In the commercial (real) world, you never do that. You file via the most expeditious means because time is money.
If in the million to one case that you lose all comms, i.e. cannot transmit or receive, then it is pretty simple. The airspace is yours. Hold at your clearance limit until your ETA, then you can proceed direct to the IAF and do whatever approach you feel is appropriate. It is not like ATC is wringing their hands and screaming, "What is he going to DO?!?" They know you will find the ground, hopefully before you run out of fuel. They will be holding IFR arrivals and departures until you call someone on the phone or the tower (if applicable) gets a visual on you.
When we file IFR into Seattle or LAX, we file arrivals that terminate in a heading. What if we lose comms? Do we panic and keep going in a straight line until we run out of fuel? No, you enter a hold at the last fix on the arrival until your ETA (departure time plus ETE), then proceed to an IAF and due a full procedure approach.
