DC-9/MD80 pilots...
  • Thread starter Thread starter aa73
  • Watchers Watchers 10
aa73
When is it a good time to turn on your wing landing lights for landing? So far I've heard:
-coming down through 10,000 (youch, still doing 250kts, they vibrate like hell!)
-when extending the slats
- below 220 kts,
-cleared for the approach or cleared for landing
-some don't use them at all, they just use the Nose lights on BRIGHT.
Opinions?
thanks,
73
p.s. I'm researching this out of curiosity. At AA we are discouraged from using these lights for fuel savings and "buffetting".
RJones said:
Just wondering ... how much fuel do you think AA will save?
Exactly. You're talking about the nickel and dime experts here - after all, they saved how many $$ thousands by eliminating one olive from the salads?
Not saying I agree with our procedure. Just curious how everyone else does it.
At my former employer ;) , we did it at gear down. The vibration causes the filiment to break. That's where the cost comes in. The incidence of burnt out lights dropped dramatically when we changed the policy.
With strobes and ice lights on, there's plenty of illumination.TC
We put the wing lights out at 10,000. In fact we turn all the lights on at 10,000. Yeh they make for a less than smooth ride but it's not that bad. We had one MEL'd in the down position and it wasn't that bad of a ride at 310/.760
"10K, Speed and Lights".
If you want to bring her down a little faster, bring the lights out sooner.
We leave our lights on climbing thru 10K and then back on again descending thru 10K. Of course, the majority of time our 9's are flying is nightime. I just don't think the fuel savings would be significant. Descending out of 10 you are usually at flight idle anyways (well, we are).
I really don't think the vibration is that bad from the lights. Of course I've never had a box come up and tap me on the shoulder and complain.:D
Trust me, if it saved fuel or money, we would be doing it. That's how copper wire was invented. Two of our managers fighting over a penny.:laugh:
BTW, I don't think the fuel savings on the olives were significant enough for him, so I think he eliminated all of them and saved $40,000 per year. I just finished that book not long ago.
Come on, you guys don't slow down!!!!:laugh:
I think it's a great idea and procedure - unfortunately, our management is more concerned about burning out bulbs, along with the (ridiculously) low extra fuel consumption.
This is the reason you will see, a lot of times, some of our MD80s taking off from DFW or ORD with just the Nose lights on bright, and then when the gear retracts, badabing! we have a stealth jet.
(Occasionally we'll have some takeoffs where the F/Os even forget to turn on the ground floods and wing/nacelle lights, so now they are TOTALLY dark except for strobes and beacons.) This is because the use of those lights is at pilots discretion, they are not mandatory.
Not factoring in the vibration from things sticking out the side of your airplane a'la MD products and the lower fuselage lights on the B737NG's, why has someone come up with the 10,000' number of light illumination? seems like FL180 would be better since that is the floor of controoled airspace. Any thoughts on this reasoning would be appreciated. BTW, I'm in favor of the FL180 number in case you can't tell already.
No clue where that number came from. Maybe just a nice round number.
Our procedure is to turn on the wing/nacelle/turnoff lights out of FL180, then the landing lights come on at 10K, nose taxi lights come on with a landing clearance.
I used to do it that way as well (15 years ago) then one day a mechanic told us to mount the bulbs with the filaments vertical instead of horizontal (we had the option) and bingo, the problem went away.
'Sled
The Speed is so they remember to answer "250" to the "Say Speed" call.:D
The vibration for the extended landing lights is much more pronounced when you accellerate about 250kts.
HAHA!!!!:laugh: Pretty well known quote:
ATC: "XYZ airline say speed"
XYZ: "250"
ATC: "Southwest xxx say speed"
SW: "Also 250"
ATC: "Well Southwest xxx, we're going to need you guys at 210, 'cause
your 250 is 40 kts faster than XYZ"
SW: "slowing to 210"
Another one I heard was:
ATC: Southwest say speed.
SW: 250
ATC: I don't even know why I ask anymore.
Okay, I realize this thread is about the MD80/90/DC9, but my questions was directed at other aircraft operators. Not a big deal, I happen to think that FL180 makes more sense assuming you don't have any aircraft/airframe issues.
