Dassault Falcons
nwf800
Does anyone know the difference between the falcon 10 and falcon 100 and then the falcon 20 and falcon 200
The difference between the Falcon 10 and the Falcon 100 is basically just avionics... They share the same pilot type rating (DA-10)
The differences between the Falcon 20 and Falcon 200 are tremendous...
Different systems (the 200 has basically the Falcon 50 systems)
Different engines Falcon 20 has GE CF700's (up to 4,500 lbs of thrust in the 2D2 version), the Falcon 200 has the Garrett ATF-3 engine (5,200 lbs thrust)
Wing is different
200 MGTOW is 32,000 lbs vs. the 20's MGTOW of 28,660 lbs.
Different pilot Type Rating.
Here is an article I found after typing all of the above... http://www.pocketprotectors.com/atf3/F200.htm
Da-200
I would think the 200 is pretty sporty. The ATF3 may not have been that durable but it did make decent power and we carried lots of extra weight in the HU25. Anyone know how many 200s are still flying?
MT
33 produced, 33 still active. 0 Written off.
25 operated in the US, 8 outside. Just in case you are wondering there are 6 for sale.
There are some perks to being a broker... some not many.
any chance you can find a list of the ones for sale cause the company i work for is looking to get ride of their lear 35 for a falcon 200
Your company would be a lot better off getting a 20 with the retrofitted TFE731's, my understanding is that the engine on the 200 the ATF is originally an engine produced for the military (Coast Guard) and they are expensive to maintain. Carl Muhs at Mid Michigan aviation at MBS is a true Falcon Guru and I would suggest talking to him before you settle on a paticular Falcon,I have heard some mixed reveiws from FA200 operators as being maintence hogs kinda like early Citation 3s.
VERY TRUE... Plus I have heard that the Coast Guard pretty much has all the spare engines tied up, so getting parts or a loaner engine would be VERY difficult...
Either get a Nice Falcon 20F retrofit (with the 5B engines) or get an early Falcon 50...
Atf3
Yep. CG is the primary owner of the ATF3 stock. There has been pressure to re-engine but that isn't going to happen now. The HU-25 is being phased out as the CASA comes on line but the timeline remains fuzzy. There may be a slight chance that as the CG lays up their birds that a window of availability could provide some relatively inexpensive short term consumption, but definitely not a long term play.
The durability of the engine is finally coming around but they are still $$ to overhaul. Considering that we fly them around at 1000 feet over salt water it isn't surprising that we didn't have huge TBO. We also spend a lot of time running fresh water through them after every flight.
Ya we looked into the 20f but we liked the short field performance which the 200 has but the 50 is to much for us right now. So how many 200 does the CG have in service right now? And is the CG selling them slowly or are they just going to dump them all at once. And I was looking at the CGs website and it says there are different versions of it does anyone know the difference between them
If I were to post the list, that would be like flying for free. You can email me or call me and I'll see what we can do for you. I deal almost exclusively in the Lear 35 market. Its not a bad time to sell, depending on your serial number. My email is mnaylor@aeromanagement.com or office phone is 410-573-1203 x208.
