CubCrafters Carbon Cub FX-3 Electrical Questions
Meconiates
TBM850, Carbon Cub SS, FX3 (on order)
KHPN
CMEL / CSEL / CSES / CRH / Instrument
Had some more electrical questions:
1) Does anyone know what the electrical draw is for a full IFR panel on a FX3 (G3X, G5, GNC355, two Comms, etc).
2) What does a heated pitot draw? I assume there is an on / off switch for the heated pitot?
3) In a scenario where you are drawing more than 40amp, can you damage the alternator? Or will it just supply 40amp and then the battery will be discharging?
4) Anyone running a EarthX 1200 battery? I wonder if that’s prudent upgrade to give yourself more margin of safety for a situation where you are temporarily drawing more than alternator can handle ?
I was at the Yakima factory today and was trying to finalize my build sheet. And a concern was raised that I am going to exceed the electrical capacity if I did all of the following:
- Full IFR with pitot heat
- 100w Landing light with 10amp
Breaker
- 100w taxi light with 10am breaker
- TA245 USBC dual (45w each plug) so there is another 90w / 10amp breaker
I moved this post out of the landing lights MOD discussion, probably best for its own thread in configuring a new FX-3 to be built by the factory.
Probably some questions to send to [email protected] and get Pete's help.
It was stated by @earthxbatteries not to use the 1200, the 900 is the correct battery for us.
At some point increasing electrical demands is going to go beyond the design and circuit, yeah, not stating anything we all know. So there certainly has to be limits in what is used IMHO. I don't think you can throw an "extreme" upsize to the alternator without needing wiring, fuses, on and on to support the loads.
If no one can help then I'd say you really need to dig into the documentation to pull the electrical specs for each and every LRU, component, etc. The ole AI / chatGPT on and on may help but needs to be verified.
There are two verions of the heated pitot. CubCrafters usually fits the GAP 26-10 which is the uncontrolled version. That means it is either on or off as set by the switch.
Like all resistive heaters the current depends on the probe temperature. When the probe is turned on there will be a large current peak but current will quickly reduce to a steady state value that is influenced by ambient temperature.
I cannot tell you the peak current because G3X logged data is heavily lagged. When I turned on my GAP 26-10 the data log shows a peak current of 6.5 A and stabilized current of 4.9 A with ambient 36 deg F. Actual peak current at switch-on would have been greater than 6.5 A but less than 20 A CB rating.
Don't know for sure. I expect the alternator will supply over 40 A but will overheat and may fail. I would expect the voltage to reduce as current draw is increased and that would eventually limit the current it can supply.
Since alternator is critical for sustained flight I would be inclined not to overload it.
I have an amber alert for alternator current greater than 30 A (corrected from 35 A). It tripped once very briefly after a difficult engine start.
I don't have that configuration but remember that peak avionics load will be when transmitting with AP engaged and servos at peak torque.
I did some battery current measurements on my system (standard G3X VFR plus GPS 175 and G5) a while ago, Here are my notes -
With engine running the ignition load will be about 2.5 A, not the zero increase shown in the table. Transmitting will add about 3 A.
It's easy to go over the top with added equipment. Think about what you really need for the way you plan to use the aircraft. Don't add weight, cost, and complexity for equipment you don't need for your mission.
Here is a plot of alternator and battery current for a typical flight in my FX-3. Strobes on, lights wig/wag, no autopilot, no pitot heat. Peaks were correlated to radio TX and fuel pump use.
In my journey to understand my EX-3's electrical system, I have discovered that it is not as simple as just adding up current draws. I then switched to adding up average and peak draws but that still does not match reality. Very few things behave on face value. Some examples.
  • My EarthX battery has a specification of no more than 80 Amps of charge current and yet it works fine with a 40 A fuse. The battery will draw significantly more than 80 A if fully discharged and connected to a power source capable of more than 80 Amps so for example connecting it directly to a 120 A alternator will cause bad things to happen. However, the battery is almost never fully discharged (when you need to use an external current limited charger to charge the battery before use) and the 40 A alternator does not produce full power at 1000 RPM after start so in practice, everything “just works”.
  • Some power draws are constant power (e.g. XeVision LED lights) such that the current draw changes with voltage but not time.
  • Some power draws are very time dependent (e.g. WAT LED lights drop greatly in the first few seconds and does not level out for 15 min).
  • Some power draws are very conditional (VHF AM radio transmit)
  • Some power draws are inversely proportional to outside temperature (e.g. pitot heat)
So overall, just adding numbers does not really work.
As far as
My measurements indicate that the full "IFR" panel (including AP servos) draws approximately 5 A at 13.2 Vdc, with a peak current of 8.5 A. This differs from simply summing the average and peak current draws; without the AP servos, the average should be 8 A and the peak 12+ A.
The heated pitot draw is inversely proportional to OAT and airspeed; at lower OAT and higher airspeed, more power is drawn. I do not have the temperature-regulated version, as I plan to use pitot heat only when required, not as a precaution (I have GPS speed and known power/performance while I wait for it to melt). The temperature-regulated version reduces average power consumption while on and prevents people from being burned on the ground.
When the alternator is overloaded (a normal condition, especially just after engine start), its voltage output drops, reducing the power available for tasks such as main battery charging. Remember that you only get 40 A when the RPM is above 2500 RPM, and the temperature is cold.
The ETX-1200 is for more starting current not for more capacity. The ETX-1200 might supply too much current to the starter motor causing damage. The ETX-680 is correctly sized and the ETX-900 is oversized.
Breaker
You will not damage anything, but you may not have the IFR reserves you expect if the alternator or main battery fails. Remember that on landing, the alternator is not producing full power (the engine is at idle), so the battery will support some of the power draw on final and during taxi, and you might need to idle for a couple of minutes to recharge the main battery after powering off the lights, pitot heat, etc., before shutting down the engine.
I have never seen negative battery current with engine running. I alert for that condition. My alternator will power all my loads at idle and is capable of at least 33 A battery recovery at 1,200 rpm
I think you are overstating the low rpm case but, if not, perhaps you could share your data.
Here is a sample of my data that shows alternator output and rpm after a difficult start.
Overloading the alternator is not unusual and happens after every engine start, as with the engine at 1000 RPM, the alternator is not producing enough current to fast charge the main battery. If you watch, you will see 20+ A and a main bus voltage below 14.1 V, indicating the alternator is "overloaded" because the voltage is below the regulated level. The battery will charge in a couple of minutes, and the voltage will climb to 14.1 V, indicating that the alternator is no longer overloaded.
The alternator is designed to be overloaded for short periods without issue. Excess current draw will cause resistive losses in the alternator both dropping the output voltage and heating the alternator which will increase the alternator temperature. The rise in temperature increases resistance, reducing the output voltage and, in turn, the field current, further decreasing the alternator output. The structure of an alternator creates a built-in overload protection system.
An alternator is rated to produce full power (e.g. 40 Amps) at >5000 RPM at room temperature. I have not measured the alternator temperature in flight, but from memory, the FAA suggests you should expect no more than 80% of the rated alternator power at cruise. If you add to that the reduced RPM of the engine at idle, the charts that I can find suggest about 70% of rated power available (remember that the alternator will be hot, and with the 3.25:1 gearing of the alternator belt on the CC363i, an engine rpm of 1000 RPM is 3250 RPM for the alternator).
I have an amber alert for alternator current greater than 35 A. It tripped once very briefly after a difficult engine start.
Yes - for a 40 A alternator to output more than 35 A, it needs to be cold and the RPM to be greater than 1000 RPM.
The issue is that with bright lights (2 * 100W landing lights and 1 * 100W taxi light) drawing 22 A, the avionics (8 A) and misc. draws such as ignition (2 A), fuel boost pump (5 A), etc. it is very possible to be drawing more power on landing than the alternator can supply and hence requiring the main battery to support. If you don't have high-power lighting, it will require very cold temperatures with pitot heat.
I will need to review my G3X logs, but I know the main bus voltage is only 13.2 V immediately after engine start, and the battery charge current increases with RPM thereafter. The engine is normally cold, so I have not pushed the RPM to determine the required RPM for full alternator output. According to the documentation, full rated power is not available until 1500 RPM or more (1500 * 3.25 = ~5000 RPM).
This shows a peak current of 33 A (82% of rated) at approximately 1200 RPM (~4000 alternator RPM) at room temperature. This seems to agree with the documentation I have seen online. Once the engine warms up, you should expect to lose an additional 10% or more of current output, but the battery will be charged before then, so it is hard to observe in a stock EX-3.
I have no reason to believe the 33 A was limited by the alternator. The current drawn by the battery after engine start depends on how much it was discharged during starting. Alternator current after start is usually much lower than 33 A simply because the battery was not discharged as much.
So far you have shown no data. Do you have alternator current instrumented and recorded on your aircraft?
I have no reason to believe the 33 A was limited by the alternator. The current drawn by the battery after engine start depends on how much it was discharged during starting. Alternator current after start is usually much lower than 33 A, simply because the battery was not discharged as much.
If the main bus voltage was 14.1 V at the time you recorded 33 A, the current draw was battery-limited. If the main bus voltage is less than 14.1 V, then the current is alternator-limited.
So far, you have shown no data. Do you have an alternator current instrumented and recorded on your aircraft?
I do not have alternator current monitoring, but you can see the effect just with engine RPM, main bus voltage, and battery current. Here is a recent set of stop-and-gos at a local grass strip from engine start:
As shown, the battery's peak current immediately after charge was 28 A at 13.6 Vdc and 970 RPM. The alternator is unable to provide enough power to maintain the main bus voltage at the alternator's regulated voltage of 14.1 Vdc; it does so 10 min later, once the battery is fully charged again. The battery current here is actually battery + electronic ignition (<2A), which is why you see the battery current vary after the battery is fully charged as the engine RPM changes. If you take the 28 A + 5 A (min. avionics + strobes + IBBS charging) = ~33 A, it is about the same as what you measured.
The 33 A peak was at 20 sec. At that time 33 A, 1120 rpm, 13.9 V.
The plots show that alternator current was decoupled from rpm after time 15 seconds which was 2 seconds after the engine started cranking.
This data set shows no evidence of the alternator output current being limited by engine rpm.
