Meconiates
Active member
- Sep 21, 2025
- TBM850, Carbon Cub SS, FX3 (on order)
- KHPN
- CMEL / CSEL / CSES / CRH / Instrument
Had some more electrical questions:
1) Does anyone know what the electrical draw is for a full IFR panel on a FX3 (G3X, G5, GNC355, two Comms, etc).
2) What does a heated pitot draw? I assume there is an on / off switch for the heated pitot?
3) In a scenario where you are drawing more than 40amp, can you damage the alternator? Or will it just supply 40amp and then the battery will be discharging?
4) Anyone running a EarthX 1200 battery? I wonder if that’s prudent upgrade to give yourself more margin of safety for a situation where you are temporarily drawing more than alternator can handle ?
I was at the Yakima factory today and was trying to finalize my build sheet. And a concern was raised that I am going to exceed the electrical capacity if I did all of the following:
- Full IFR with pitot heat
- 100w Landing light with 10amp
Breaker
- 100w taxi light with 10am breaker
- TA245 USBC dual (45w each plug) so there is another 90w / 10amp breaker
Breaker
