CRJ 200 Experts, Please share your preflight tips
tarp said:
Mike1:
Thanks for the memories. I am now furloughed from the plane you aspire to fly.
So although I want to be as sarcastic as possible all I can do is tell you the truth and here it is:
For the next few months you will try to do the best g'da$n job you can including your preflights. Then you will be paired with "THE" captain and he will teach you everything you wanted to know about preflight for the airplane. He will show you stuff that you "only get from the Tech Manuals". You will hate his (or her) guts. He or she will ask you "how many things you found wrong with the airplane and woe be to you if you don't find the same things. A four-day pairing will feel like a month. A month will seem like a year. You will cry to get away from this moron. And then you will never care about another preflight your entire career. Big things attached and nothing will get me in trouble - Done! Let me get out of this f'in weather. Believe me the ramp will suddenly get too cold, too hot, too icy or too rainy very soon. You won't care about a bonding strap unless it pokes you in the eye - with the door closed it's probably grounded anyway. Hydraulic leaks are going to have to be whoppers to cause a delay. Paint - ha, ha-ha, ha, ha, ha, ha, ha - After you've worn through the airline colors, the base white, the green zinc oxide and you start seeing holes in the aluminum and fiberglass - OK, now I'll worry about paint.
Do the best you can - it's better than 70% of the rest of your fellow crew members and good luck. I'm sure glad I'm not working for $19K a year doing preflights in Burlington, VT or god forbid, Fargo, ND in December.
Phony Marconi said:
Mike:
Great thread. Too bad some of the replies here mistook your idea as being that of a super-geeky newbie F/O who wants to restore each plane to factory-new before every flight!
Thanks for the great stuff so far everyone! Lets up the safety level even more!
Two more good ones are the Placards for the oxygen door and ADG door.
BLing said:
I remember one day when I was working ramp for Pinnacle an FO did a walk around and didnt even notice that the whole tail cone was covered in speed tape. I asked the FO during his walk around what had happened to the plane. he had no clue that the plane was taped together. I noticed it as the plane was landing. Youd think somehing like that would be noticed during the pre flight when its right in front of your face! That makes me wonder what else this idiot misses??
Not to defend that FO, but I do walkarounds every day that I work and after 3 and a half years I sometimes wonder how much of an abnormality there would need to be for me to notice.
It's kind of like when you look at your watch and as soon as you take your eyes off it someone asks you what time it is and you can't tell them without taking another look. Sometimes I feel like that with gear pins. I know I looked at them but I always have a little bit of doubt when the Captain asks. After having done walkarounds for a while without finding anything significant I notice that my my mind does tend to wander.
I'd like to think that I would notice a tailcone covered in speedtape but, as I said, sometimes I wonder.
When ever picking up a new plane, I aways look in the aft equipment bay. Anything that can make your day go to $hit really real fast is located there. I've found tools bails of safety wire left behind by maintenance. really don't want things like that bouncing around back there in turbulences.
Just cause it is covered in speed tape doesn't mean it isn't the way it is supposed to be. I doubt the speed tape was holding the Tail cone on. Go look at the winglets, those things are taped on.
Speed tape is mostly used to protect epoxy as it cures. If it was on the tailcone, it very well could have been a repair of a lightning strike. I've seen that one several times.
Thanks, I'm yet to see it on the tailcone, but your explanation makes sense. I have seen it put on wing tips and and winglets to protect them from rock damage.
Not sure what you mean by good ones? Are you preflighting your aircraft or trying to point out the many items that would ground an aircraft. PLEASE, PLEASE don't be that guy. Every company has a few, and trust me you dont want to be that guy. You will impress no one and annoy so many. (px, scheduling, fa's, rampers, mx, dispatchers, your pilot group, etc...)
skydork said:
And as a wise man said, sumb!tch flew in, sumb!tch'll fly out!
Try telling that to the 3 crewmembers and 11 passengers that lost their lives in an EMB-120 on 9/11/1991 over Eagle Lake, TX.
Speed tape is different from erosion tape. The speed tape metallic and is aluminum colored and erosion tape is opaque, and vinyl based.
Uh..that would be like....totally impossible :erm:
Two wings, two engines, nav lights working, and nothing leaking. Captain, plane's fine.
any damage to the main pax door seal area, usually caused by closing door without red strap attached
ground straps:
main pax door - under top step on right side
all access panels
all gear door panels
under spoilers and spoilerons
ailerons and flaps
any holes in radome clear adhesive cover
hairline cracks in main pax door hinge
aileron and flap seals
caulking required around outside of nav light housing
chain that holds gas cap on
any dings or significant scratches on leading edge
any dings or scratches on fan blades
Placards that are commonly missing or damaged:
oxy door
nose gear door
adg door
Any cut in tires. Don't be a mechanic and dig into the cut to try and find chord, that is not your job. Have a mechanic sign off on it even if you're at an outstation.
Oil splatter on FDR, viewable from vents at very rear behind aft equip bay door.
Cockpit:
2 replacement fuses behind FO are always broken/missing.
visible moisture coming from air vents means the "socks" that filter the air are old and moldy. If captain says anything otherwise tell him you refuse to breath moldy air all day and you're writing it up whether he likes it or not. This is not a joke, ask the mechanics to show you the sock and you'll know what I mean
all cockpit lights must work
yoke writing pad angle adjustment is always busted.
don't fly with 7 year old seats that are so uncomfortable you need a chiropractor after a day of flying
any and all unusual status and caution messages on the taxi out. You should NOT feel comfortable with your captain pulling out his dandy magic circuit breaker list. It is not his job nor yours to pull circuit breakers unless directed to do so by mx or emergency.
NOSE WHEEL SHIMMY ON TAKEOFF!
I had one shimmy once, wrote it up and found that it had not been installed correctly.
It is also extremely important to understand that a discrepancy is a discrepancy whether you find it at C23 or at an outstation. Do not wait until "we get back to atl" to have something checked out. That is why we have outsourced mx at outstations.
Besides safety, another good reason to follow this rule is that it has happened numerous times where the FO will do the walkaround, only to have a fed preflight after the FO and find things wrong.
It is not worth the risk, and our company has acknowledged and reinforced that strongly by the latest bulletins stating that ALL discrepancies MUST be written up.
The CVR must be bright orange with 2 strips of reflective tape. You can see it through the vents on the right rear.(Use a flashlight)
CRJ200 main door pins that FA verifies are painted over on many planes and are white, but should be green. Think it grounds the plane.
I'm brand new here and want advice on the preflight.
For instance,
Pax door ground strap (under top step) either chaffed or cut.
**This is in no way connected to the fact that negotiations are not moving along, nor the fact that our crew bags are now needlessly denied entry into a warm, dry, and safe place.
the proper technique is to walk around the A/C in a clockwise fashion while watching other airplanes as they fly over, then enter the jet bridge and get back in the plane.
When I preflight the CRJ. I will wear rubber gloves. I will not touch the exterior of the airplane without protective gloves on my hands. There's alot of dirt oil etc etc. Get a pair of latex gloves.
The communications service panal on the nose:
The test light for the:
1) Parking brake(Red)
2) The AC power(amber)---not sure
I do not think these are in the MEL
But this is just what someone told me. I have not looked any of this up in the MEL.
They're not...but they use the same bulbs as the switchlights in the cockpit and you probably have some spares onboard.
Sorry for the cross-post!
You all should really be looking at the fabric seal between the inside of the cargo compartment and the cargo compartment door. Any rips or tears, and it is a no go item. This fabric is often ripped up by careless rampers loading bags. Not MEL-able last I heard. While your looking at the seal, check the protective lower door sill cover. If it is dented, the door may not seal correctly, leading to pressure problems.
Today, we had Mx in ATL... swapped to another aircraft that had serious MX.. swapped to another aircraft that had minor MX... left for the outstation 4 hours late. Man, the RJs are just falling apart!! Thanks, crews, for all you do to ensure the safety of the fleet.
For instance,
Make sure the cockpit seatbelts do not have any fraying at all. They were designed without frays and any fraying will reduce their designed strength and effectiveness. Good luck and FLY SAFE!
Just check to make sure they're not any dead/frozen boarder hoppers in the gear bay, and we're good to go.
And the flashlights, don't want find out the batteries are dead when you need them. Mtc can help you out. Be sure to check the stby a/s indicator on T/O, they sometimes get water in them and need to be serviced. Since your new you will be told how delicate the knobs are and if you jiggle them too much they could break as this plane was not made for regional flying but corporate flying. Good luck, you do a very diligent pre-flight so my family will be safe. Safety first, on-time, well hell nobody else obviously cares.
Make sure you're at an out-station when you do this one. They now have a document that explains the tolerance of the belts. Needs to be more than 10% of the width frayed. Easy inspection for mx in ATL, but could take a while for contract mx to inspect it at an out-station...
Mike 1:
Thank you for your concern for aviation safety.
My own pre-flights will be improved due to this post.
One more item that is often ignored or overlooked is the compass correction card. It is important that those are there.
