climbhappy
ex pat
- Aug 11, 2002
i'll do you one better...had the Fed on board for a 3 hour tour, a three hour tour
We left MCO for SJU. VFR, had just flown up. A retired Delta Fed was riding to go pick up a plane. he had busines and really didn't want to hose us, plus he flew for 40 years.
So, The Capt gets a flag on his ATT Ind. We run the checklist I am flying and then he says," you check me on the checklist and I have the plane. meanwhile the Delta Fed is watching this. we're climbing out, still VFR and will be so till altitude.. I back him up and we keep going and now he gives the plane...
(later the fed would say, "you screwed up , He had the good side")
we call maint and we look at the MEL. the revision to this item had been deleted. We had told our maint that the Fed was on board and he says, " you 're on your own."
We talked and elected to continue since at altitude we could see and avoid plus the Fed had a reason to go there. he was bringing back a 757 for Delta.
At the end after a easy ride down, the capt was sweating bullets. he was so nervous at one point the ASI indicated 253 even though the speed selected was 250 on the panel.
The Fed said you fine but don't ever take the controls from the guy who has the good side plus he was peeved at our maint for saying "you're on your own"
It was the funniest leg I have had in 10 years in this business. Nervous Nellie captains don't handle these things well. It is nice to be back in the left seat...
I would always solider on if you have the fuel, weather, and it is non safety item.
