netjets_pilot said:It's when the fan in your air conditioner's compressor (outside your house) stops spinning. You have to go outside and hand prop it to start it again.
ultrarunner said:Hey dude, shouldn't you be at a picket line that no one cares about?
Yeah, I thought so.
ultrarunner said:In simple terms, turbine blades in a turbine engine require correct airlfow over them in order to operate efficiently...much like a wing.
When this airflow is disrupted, such as with extreme angles of attack, inadequate airflow, etc.. the compressor (s) (blades) will stall....
It commonly occurs when take off thrust is applied and a sudden cross wind occurs across the engine inlet, disrupting the airlow. Lots of banging and erratic engine indications.
Another common occurrance is when a flight crew attempts an engine start at or very near the tail-wind component limit for starting.
Compressor stalls can also occur during flight. And a classic example is the RJ that crashed several months ago after a dual flame-out.
Hope this helps you a bit.
Yeah, I thought so.
flyboyzz1 said:Thanks!
ultrarunner said:When this airflow is disrupted, such as with extreme angles of attack, inadequate airflow, etc.. the compressor (s) (blades) will stall....
