I sure hope the above quote isn't indicative of the quality of investigation. The logbook (maintenance can) placed in the airplane, which would be the only thing the crew would see, would not have the elevator trim cable replacement in it. That write up would be in the master aircraft logbook kept with maintenance.The captain noted to the first officer that the DFDR was an open item on the MEL; however, there is no record of the captain mentioning the replacement of the forward elevator trim cable.
How might it have saved the day?it might have saved the day.
In ANY accident sequence, there are numerous opportunities to "save the day". This may have been the last one, but it is overly simplistic to make such a blanket statement. Of course, Monday morning quarterbacking is the most simplistic form of all. And is exceedingly easy.pilotyip said:it might have saved the day.
It's NOT the end of the discussion. Period. Dot. Sure, nothing they did "caused" the accident and a properly repaired aircraft would not have crashed. But omitting a trim check that could have detected a trim system that was operating in reverse could have prevented them from ever taking off in the first place. THAT would have also prevented the accident. Like someone else said, it is never one thing that causes accidents and this one is no exception.LearLove said:I'm not saying the crew didn't skip something, but I am saying that what they skipped didn't cost them their lives.
I agree, from what I know,read and have been told there was nothing the crew did that would have caused the accident.
In both cases had the MX done to the aircraft been accomplished properly neither accident would have occured. Period, dot, end of discussion.
Where does it say they skipped a trim check?But omitting a trim check that could have detected a trim system that was operating in reverse could have prevented them from ever taking off in the first place.
It says so right here in the NTSB report disclosing the probable cause.chperplt said:Where does it say they skipped a trim check?
Sad but I thought the exact same when I read the report.pilotyip said:Sounds like the flight crew used improper checklist procedures, not using "First Flight of the Day" checklist and not calling for Takeoff Final Items or Line up checks, it was not clear in the report. it might have saved the day.
.Fix the problem, not the blame
Does the Beech 1900 have a trim position indicator? Is the indicator independent of the cockpit trim wheel, or does it have a position sensor back on the elevator somewhere?
Space Cowboy said:What is the MTOW of the 1900c and d?
What company do you fly for? That certanly was NOT the trim check at Colgan at the time of this accident.the preflight trim check is basically having one check the trim at position 3 and visually looking at the tail then resetting it to 0 and checking it again for "flushness".
