ReverseSensing
On the BC
- Apr 15, 2004
I would like to know what kind of cockpit indications there are if there is a malfunction in the de-icing boot system on any part of the airplane and/or tail.
There are two caution lights associated with the airframe deice system: one that indicates a loss of deice pressure (with a backup gauge) and/or the failure of a boot set to fully inflate after the distributor valve opens or if a boot set remains inflated after the distributor valve closes. The second caution indicates a deice timer failure.
As to your comment about torque reaction: obviously 10,000 shp applied to 13 foot conventional rotating props will require a pilot to react as you might expect. It is certainly possible that the initial left bank was due to a failure to apply enough (or any) right rudder. I don't know what actually happened, though.
