Scott,
That is practical if you're already flying with the bells and whistles. If you have an FMS issue, then certainly advise the controller of your equipment failure (as you are
required to do, and request what assistance you must. To answer your question, assuming your have experienced degraded nav capability AND it is the best choice under the circumstances, selection A: advise ATC and request alternate routing or vectors.
However, this has no bearing, nor part in the original question of the thread, which was as follows:
The other day, there I was, on an IFR flight plan to OSU (Don Scott Field) for the Ohio State Game. (Another subject all together) Level, 6000' about 12NM, east of the APE VOR heading to OSU. The controller calls me up and says Lance XXXXX proceed direct OSU. I do not have RNAV but I do have a non-IFR GPS. So, could I use the GPS and go direct? or continue to the VOR and fly the outbound heading for OSU?
Just so you are aware, at 6000' I was almost on top, in and out of the clouds. Bases were around 4500' so I did need to stay IFR to get down
The question was simple: could he use the GPS to go direct. Yes, he could, but not as a primary means of navigation. The question then followed, what are the legal ramifications. None. He could request a radar vector, but simply put, he's still legal so long as he is able to accurately fix his position.
As he was flying IFR on something other than RNAV, he had other means to accurately fix his position. We're not talking even a need to DR here, nor did anyone (least of all myself) suggest that he should. That was never the issue.
What did become an issue was those saying that without GPS or RNAV, it couldn't be done. Why, yes it can. In this case, he has GPS, albeit not approved. Regardless, it can still be done.
If he is using victor navigation and stays within the service volume, he can use that. Celestial nav is possible (don't know about you, but I do follow stars and constellations any time I can see them at night, sextant not withstanding). DR is a possibility. A combination of timing and electronic navigation is possible. The use of radar, vectors, and position fixing by that means is possible. Any combination of these is possible.
Further, the poster stated, as quoted above, that he could continue the flight outside IFR if necessary. There was no good reason why he couldn't continue the flight using his unapproved GPS, and could easily have been legal...either IFR or VFR.
My issue comes with those who are so small minded and who have let their personal skills deteriorate so far as to think that alternate means aren't possible, or aren't safe. That is simply false; it smacks of ignorance. So I ask again, just how do you think we did it before GPS?????????
