Logical falsies:
A Post Hoc is a fallacy with the following form:
A occurs before B.
Therefore A is the cause of B.
The Post Hoc fallacy derives its name from the Latin phrase "Post hoc, ergo propter hoc." This has been traditionally interpreted as "After this, therefore because of this." This fallacy is committed when it is concluded that one event causes another simply because the proposed cause occurred before the proposed effect. More formally, the fallacy involves concluding that A causes or caused B because A occurs before B and there is not sufficient evidence to actually warrant such a claim.
Not surprisingly, many superstitions are probably based on Post Hoc reasoning. For example, suppose a person buys a good luck charm, does well on his exam, and then concludes that the good luck charm caused him to do well. This person would have fallen victim to the Post Hoc fallacy.
Post Hoc fallacies are typically committed because people are simply not careful enough when they reason.
