Citation Mustang
What is the longest legs you are seeing? Also is the AC freon or ACM?
Happened to see some fuel placards on one. Carries just shy of 400 gallons...sooooo....100 gph x 4 = a 4 hr bird, then glider.
So I'm thinking a 3 hour plane with good weather and a 2.5 hour plane in bad weather.
Hmmm...so, 3 hrs blocking 300 knots or so? Seems reasonable block for that plane....900 nm with good wx, and a couple hundred less in bad.
Doesn't seem too bad.
Sure, but how many pax can you fly with full fuel? 1,2,3,4? Not sure.
Sounds about right...
8645 gross - a typical BWO of 5400 - full fuel = about 640 lbs or so...depending of course on the actual BOW.
So it's basically one-crew and two pax with bags. Maybe one more body if they are all small...but everyone is getting fatter...so it's a three person plane on a max-range mission.
