Citation Encore Vs Lear 35
who gives a rats a** about what "you see" on the airspeed
what do you see on the paycheck
jesus christ
More relevant is what mach you were running at. TAS will vary with temp.
And, when calculating TAS, did you remember to take into account the mach error on the non-Rosemount probe Lears?
As for the job question, like everyone else said, choice of airplane is very much secondary to quality of company and job.
CapnVegetto said:
What did you run it at? Straight out of the book 795 degrees ITT for max cruise is what we ran it at. 460 almost every time at 370.
Edit: Also had DEECs instead of EECs on ours, so the engines performed a little better than on the older ones. With the DEECs turned off the power output of the engine was noticably less. 795 ITT got you a LOT less N1 without DEECs than with.
Capthuff said:
the only time I see 460kts is in the low 30s, in the 40s you'll see 440 or so...
That's the case with any jet aircraft. Best #s are going to be in the 30s. Citation X for example won't see a hint of .92 in the 40s, but if you have to get there and need the speed, drop in down into the 30s and hang on. Efficiency of the fan drops of considerably when in the 40s, but it does not have to work as hard, so the fuel #s go way down.
Capthuff said:
you made it to 230 in 5 minutes? so what - you're still in the trop. try getting to 430 in 17 minutes. thats my best time in the 31
You were light, it was very cold, you had an unrestricted climb, and when you arrived at TOC, the 31 was on it tail and not on speed. I think what CaptV is trying to say is proven here in your statement. You made it to 43 in 17 and that is some sort of record. In the Encore with the P&Ws, that is just another day at the office; not a big deal. The LR60 will do that all day long and it has a little stronger version of the same P&Ws the Encore has. Garretts are nice, but at the end of the day, they get romped by the Pratts. Falcon moved away from the Garretts on the 7X and F2th and put P&Ws on them. The 2000DX is at 410 in 17 minutes and that is a normal profile. The 7X is their flag ship, and the trusted Pratt to get the job done and they are getting better than expected performace out of the airplane, so much so that they are considering putting winglets on the 7X to eek even more performance out of it. Next time you see a LR60 or Encore taking off, stand out there and listen. It is much quieter than the Garretts; be sure to go to the 1st 1/4th of the runway, cause they dont need much to get airborne.
Capthuff said:
But I do believe that overall the Citation is a better product than the 30 series Lear. But the 40/45 has them both beat by a mile. That is why we are selling the 31 and getting a 45.
a nice Christmas present for me.
You are selling the 31 cause the boss figured out it has no range. The 40/45 still have Garretts on them, so it might have a little bigger interior, but it will by no means out perform the Encore. It has more range than the Encore, but in terms or raw performance, the Encore has is beats. Bombardier took a plug out of the 45 and called it a 40 along with a few other changes, but that plug they took out of it was the only part of the 45 that worked properly. The month long 45 fleet grounding was also a welcomed surprise I am sure. Go fly something that has P&Ws on it, and you'll be singing a different tune.
.79-.80 all day long. Redline of .81. And yes, we had Rosemont probes. Came with the RVSM package. We had RVSM certification a year before it took effect. TAS was calculated by an instrument we had connected to the system that also calculated the SAT. You could also calculate it in the CALC mode of the GPS.
It may be time for a thread on powerplant management, but not today...
Put simply, you really shouldn't use ITT as your primary power setting reference on Garrett TFEs. The manuals use N1 for proper power settings with ITT "not to exceed xxx degrees." On nice fresh, strong engines the appropriate N1 will be achieved with comparatively lower ITTs. Older, more worn engines will require more "heat" to achieve the appropriate N1. ITT (and N2) is more indicative of engine health or condition. If you've got strong engines, running them at the ITT limit can exceepd the N1 recommendations - but the airplane will sure fly fast.
Merry Christmas
'Sled
Normal cruise in the 35/36 is .76/.77. All pushing to it .80 does is reduce the range. According to the folks I have talked with a Learjet (and this was before Ski-doo jet took over) the most efficent speed for the 35/36 is .75. It is due to the aerodynamics around the wing and engine nacelle area. It is my understanding that the Risbeck XR mod has resolved much of those aerodynamic issues.
We had a pilot who insisted on flying our 35 like a 25. All he managed to do is require a fuel stop after 3 to 3 1/2 hours. The rest of us are able to get around 5 hours out of it.
That was my experience as well. If you try to push that relatively straight wing through the air much faster than .77 or .78 all you do is get a way disproportionate increase in fuel burn for what ever increase in speed you get. I usually flew ours at a .78 constant mach which usally worked out around 430 ktas. It's been 10 years since I last flew a Lear and I don't know what effect the new RVSM mandated ADCs have, but the I remember that the ADCs on the aircraft with the 200 autopilots indicated about .02 mach higher than the 530 equipped airplanes.
All of the factory stats I ever read on the 35 listed 440 knots as cruise. My guess is that CapnVegetto is probably running his airplane "balls to the wall" - not particularly the most efficient way to fly the thing.
'Sled
Put max fuel on the old Encore and then tell 4 pax they ain't going. It's what,a 700 pound payload with full fuel? Full fuel on the 45XR still gives you 2,000 lbs payload with 1800NM. Encore is VERY anemic.
Put simply, you really shouldn't use ITT as your primary power setting reference on Garrett TFEs. The manuals use N1 for proper power settings with N1 "not to exceed xxx degrees." On nice fresh, strong engines the appropriate N1 will be achieved with comparatively lower ITTs. Older, more worn engines will require more "heat" to achieve the appropriate N1. ITT (and N2) is more indicative of engine health or condition. If you've got strong engines, running them at the ITT limit can exceepd the N1 recommendations - but the airplane will sure fly fast.
Merry Christmas
'Sled
That's a matter of operational preference. While I agree with what you have written, some Garretts do use ITT for the power settings. In the Hawker 700s, it was 865C in the climb. That is how you set the climb power. If you wanted max power at cruise, leave it there. That was max cont. and Garrett published those #s and its what is reccommended. You could also reference Max N1 #s, but it was at the discretion of the operator. Remember, most of these engines are on MSP, so if guys operate the TFE in the manner which you say they should not, and it does not affect the MSP policy (they all have tattle tales), then it must be OK with the Engine folks.
Nice, but the boss didn't pay us to be efficient. He specifically wanted us "flying fast", so we did what he wanted.
HawkerF/O is right. In the manual, Max continuous temp is 832, which means you could cruise it at that. However, for "maximum engine life" as stated, you are recommended to run cruise power at 795. Straight out of the manual. There is a climb power setting chart based on N1, but I've never seen one for cruise in any manual.
Also, NOWHERE in the Simuflite manual or the Garrett TFE731 manual have I ever seen a cruise power chart. You're probably right b/c there is one for the CE-650 I fly (same engines) which gives a power setting, then a temp, and you're supposed to set the power or temp, whichever comes first, but it's almost always the temp. I checked it out last night to verify my numbers. However, I still have the Simcom manual and I will check it. I don't have access to the actual AFM anymore as I don't fly one anymore, but the point is, .80 gave me 460 or so on the TAS meter at 795 ITT. People can argue with me all they want, but that's how I ran it, that's how the boss wanted it ran, and that's what I saw. End of discussion.
I've already stated that the Encore has less range than the 45. So whether it's 100 NM or 800 NM, less is less and I have already said that, so why bring it up again? Now, let's talk about going 1000NM. You'll see the Encore clown the 45. It's out climbs it, burns less fuel, can take more people, and will arrive sooner.
Also, you mention the OLD ENCORE against the 45XR. Why the old Encore against the newest 45? Lets put the old Encore against the old 45 without the XR mod. What do you have to say now? Pull those #s out for me. The old 45 still gets clowned, but this time, the 45 stops for fuel, the Encore does not.
A lot of people would agree with you, but I've had a series of long discussions with the folks at Allied Signal and that's not what I was told. There is a certain amount of operator discretion, but the bottom line is if you want to achieve book performance (range/speed/FF) you have to fly the airplane by the book.
I do know that the AFM in the Hawker is a little different than what is found in other aircraft so I won't disagree with what you are saying. I would ask to double check it though - I think that you might see that your climb power and max cruise charts reference N1 values with "not to exceed" ITT values.
'Sled
The 35 has -2s the 650 has (I believe) -3s. They are not the same engines. There were cruise charts in the Lear AFM as well as in the FlightSafety QRH.
'Sled
'Sled
The original question was Lear 35 vs Encore. Well all things being equal (Pay, QOL, etc.), I'd go with the Encore, for a simple reason that the Encore is a $6.5M airplane and a Lear 35 is a $1.8M airplane.
I'm not getting into the "which airplane is better" argument, but an Encore is worth on average $5M more than a Lear 35. That gives the operator a lot more options and possibly stability.
I had an Excel pilot tell me the same thing. After the second time, on a identical trip we out climbed him and passed him up in the climb, he re-thought his statement. We each had 8 passengers and doing the same trip. It took him a while with the head winds at FL400 while we went straight to FL450 and didn't have to stop for fuel. Yes, we have the 45XR...but I did let him take off first.
