PimpJuice
Pete Schwetty
- Jun 23, 2005
> Chuck Norris doesn't request clearances, he states intentions.
> Chuck Norris never gets vectors to final . . . final gets vectored to
> Chuck Norris.
> Chuck Norris is the only person ever to land on runway 37.
> Hijackers squawk 7400 when Chuck Norris is on board
> Chuck Norris doesn't use a radio. He just yells.
> A hung start is not a concern for Chuck Norris, he has always been hung.
> Chuck Norris once shot down three enemy aircraft with his blivet.
> If you ever lose sight of Chuck Norris, check your six o'clock.
> When Chuck Norris taxies onto the runway, incoming traffic is told to
> hold short
> Chuck Norris never "loses" altitude, he simply gets rid of it when he no
> longer has any use for it.
> A precautionary approach according to Chuck Norris is sneaking up on
> someone from behind right before he breaks their neck with a judo chop
> Chuck Norris has never landed with a crosswind. The wind would never
> dare get cross with Chuck Norris.
> Chuck Norris doesn't fly into headwinds...the wind is always running
> away from Chuck Norris.
> When Chuck Norris flies, the altimeter setting is 00.00. Chuck Norris is
> never under pressure.
> When the BASH condition is Red, planes don't fly. When the BASH
> condition is Norris, birds don't fly.
> Chuck Norris does not have to worry about crashing into the ground. The
> ground will gladly get out of Chuck Norris' way.
> Chuck Norris has never had a midair collision, He has shot down any
> plane that has gotten within 10 miles
> When told to break at the numbers, Chuck Norris politely reminded the
> controller that Chuck Norris cannot be broken and proceeded with the
> straight in.
> Chuck Norris was taking the active runway and noticed the windsock was
> pointed in his direction. Chuck Norris calmly got out of his plane
> walked over to the windsock and obliterated it with a double roundhouse
> kick. No one points at Chuck Norris...no one.
> Right of Way rules do not apply when Chuck Norris is flying. If you are
> flying toward Chuck Norris, you are wrong.
> Chuck Norris doesn't shoot approaches...he kills them.
> Chuck Norris is never off of glideslope, the glideslope is off of Chuck
> Norris
> Two way contact for Chuck Norris is when he hits you with both fists
> simultaneously
> Once, Chuck Norris was told to down one of his students. That student is
> still recovering from his injuries.
> Chuck Yeager broke the sound barrier with his Bell X-1 Jet. Chuck Norris
> broke the sound barrier with his fist.
> Chuck Norris doesn't manage operational risk...he seeks it.
> An ejection seat is not safe until Chuck Norris gets out of it.
> Chuck Norris was told to ident, the controller was greeted with a fist
> coming out of his radar screen.
> Chuck Norris has never had a successful recovery onboard a carrier; it
> is impossible to trap Chuck Norris
> Chuck Norris doesn't level off; he tells the altimeter to stop moving
> Chuck Norris doesn't need crew rest...he never sleeps.
> Chuck Norris was once denied a clearance...once
> Shock and Awe are the names of Chuck Norris' legs
> Minimum Safe Altitudes do not apply when Chuck Norris is airborne, if
> you are in the air when Chuck Norris is flying you are never safe.
> Chuck Norris is never given the instructions "when able" . Chuck Norris
> is never unable to do anything.
> Favorable winds are always in the same direction as Chuck Norris' flight
> path
> Chuck Norris was flying and saw a wall of clouds ahead so he decided to
> punch through them. He then got back in his plane and flew through the
> hole he just made.
> Chuck Norris has never had to adapt his eyes to the dark. His infrared
> vision is working perfectly fine.
> Chuck Norris was told he was number two for landing. He immediately went
> to guns and shot the preceding aircraft. Chuck Norris does not follow
> anyone.
> The Chuck Norris One STAR involves descending to 10000, turning to a
> heading of 150 for 34 NM, and then receiving a roundhouse kick to the
> sternum.
> It is not advisable to use your heads up display when flying with Chuck
> Norris, a round house kick to the face hurts a lot less with your head
> down.
> T-45 Anti Icing Capabilities: Pitot Heat, 5th Stage Bleed Air, Chuck
> Norris
> A permanent TFR surrounds Chuck Norris...no one is safe.
> Chuck Norris' aviators are mirrored, this is so you can see your
> expression the moment before he kicks your face in.
> Chuck Norris cannot be tracked on radar, if he appears, it is too late;
> you are already dead.
> A good flight for Chuck Norris is a bad flight for you.
> A Flight Docs gives med up chits, Chuck Norris gives med down kicks.
> Leading cause of disorientation for pilots: Chuck Norris
> If you become hypoxic during flight; apologize to Mr. Norris and ask him
> to remove his foot from your throat.
> Chuck Norris never turns up the volume on his radios, he tells everyone
> else to speak louder.
> Chuck Norris once moved a stationary front.
> All survival vests will be fitted with a Chuck Norris.
> Chuck Norris is the only person to graduate SERE School via
> correspondence.
> A sonic boom is the sound of Chuck Norris smacking you in the face
> telling you to slow the hell down.
> Chuck Norris isn't holding, he is circling above his victims.
> Chuck Norris provides close air support via flying round house kicks.
> On final, an LSO told Chuck Norris he was slow; that LSO never saw the
> ensuing eight kicks coming.
> The weather outlook for the area around Chuck Norris: 100% Chance of
> Pain
> Getting acute with Chuck Norris will be your last mistake.
> There is no need to use your rearview mirrors, rest assured; Chuck
> Norris will always be there.
> Violate the 12 hour bottle to throttle rule and Chuck Norris will
> enforce the 12 hour bottle to face rule.
> Chuck Norris has never missed a takeoff time, Chuck Norris never misses
> anything.
> No one knows what Chuck Norris' side number is, nobody has ever gotten
> that close.
> There are two kinds of fighter pilots: those who have not yet challenged
> Chuck Norris to a dog fight and those who have. Unfortunately, we have
> been unable to find any who have challenged him.
> Chuck Norris.
> hold short
> straight in.
> Norris
> simultaneously
> path
> hole he just made.
> anyone.
> sternum.
> down.
> Norris
> correspondence.
> Pain
> anything.
> that close.
