Christen Eagle?
slackass
Total Time
7000+
Hey folks. I am an 8000 hr pilot looking at exploring light aerobatics and am considering a Christen Eagle. I will certainly look at professional instruction but am wondering about the reputation of the Eagle. I want to play and use it recreationally. I am a neophite in this area of aviation and am looking for helpful insight. Comments or direction for information would be apreciated.
Blue Skies!
tathepilot
Total Time
None
You should join I.A.C, also your local chapter. Start going to the meetings.. you will meet lots of good people with lots of insight. The monthly magazine is a plus, lots of great info in it. More than often they have 'fly day' where you can get some stick time in your favorite aero..
Good luck.
Headwind
Total Time
10000+
The Eagle is sort of a modern and improved version of the Pitts S2A sold in kit form. The kit is very expensive. You can buy a flying Eagle for less than the cost of the kit.
The S2A will still bring more than the Eagle because it's not expermental and you can give instruction in it.
If you don't plan to use it to give instruction the Eagle is great.
Airbum
Total Time
11000+
Having owned a S2A and a Eagle I prefer the Eagle. More comfortable cockpit with better vis in my opinion.
Get decent aerobatic training from someone with a good rep. There are several folks with decades of experince in the IAC.
Landings are also quite different from lots of planes. There is a guy down in PHX who does Pitts training. I would highly recomend him if you are looking for tail wheel training.
Sonny Crockett
Total Time
10K+
Owned Three Eagles, great airplanes!
Hazen
Member
Total Time
Enough
I owned a Christen Eagle and it was awesome. A good friend had an S-2A. I like the Eagle much more than the Pitts as long as you can live with the limitations of it being experimantal. ie not instructing in it etc. My Christen Eagle was about 5 knots faster than the Pitts S-2A, the cockpit is much more comfortable with better visibility. Hardest plane I have ever landed. Takes a little getting used to doing the rudder dance. I think the Pitts may be a touch easier to land since it has that bungee cord type suspension on the front gear. It gives a little more. I got a book on doing aerobatics in the Pitts and taught myself how to do most maneuvers. If you put the throttles at idle and let go of everything it will come out of most any out of control scenario by itself. I just flew the plane for fun and never had any desire to compete in aerobatics. By yourself with a half tank of gas it is a lot of fun. A harness with the ratchett on the waste belt is highly recommended if you plan on doing much negative stuff. I bought mine already built. Cheaper and didn't have to wait to finish building it. Just need somebody that knows what to look for when buying a built one. Being experimental, there are varying levels of build quality out there.
Airbum
Total Time
11000+
www.airbum.com is Budd Davisson's website.
He will teach you to land the eagle safely!
To clarify I am not Budd, I have met him and he is a great guy. I didn't realize he had that website. guess I better change my nickname so nobody so nobody gets confused.
JungleJett
Total Time
1
I know someone selling a BEAUTIFUL Christian Eagle. It is on Barnstormers..the black one. Having flown this airplane and known the owner for 20 years..and the knowing the guy who built it...I would not hesitate buying this airplane if I wanted an Eagle.
CHRISTEN EAGLE II • $75,000 • FOR SALE590TT, 260 SMOH, Gorgeous Eagle!! Recovered in 1999, Solid Crank, B-Hub, Longeron Mod, Wing Block Mod, 10:1 Pistons, 4 to 1 Exhaust, Smoke System, B&C Lightweight Starter, B&C Gear Driven Alternator, B&C Battery (relocated forward of firewall), 1" Gun Drilled Gear (Taller), Spades, Wing Sight, , 2 Chutes, Headset, King Comm & Transponder, Garmin 295 (color) GPS, PS intercom, Canopy Cover. Flys and Looks Great!!! • Contact Chris Shollenbarger, Owner - located Mason, OH USA • Telephone: 812-584-6392 . 513-492-9070 • Posted September 16, 2008 Show all Ads posted by this AdvertiserRecommend This Ad to a FriendEmail AdvertiserSave to WatchlistReport This AdView Larger Pictures
