McGillicutty
- Mar 3, 2006
I have no idea what's going on these days. It may be totally level playing field.
great assets
Political correctness, how gay can it get?
I spent 20 years as a Flt Standards Pilot. I've flown with women in times of peace and war and I can tell you from a training and an operational standpoint women have no place in combat.
Take the time to read the MIR one day. Feast your eyes...http://yarchive.net/mil/f14_hultgreen_accident.html
It is critical in the fact that it assumes that the pilot put the aircraft in a side slip which resulted in a compressor stall. D. Aircrew factor - MP's attempt to salvage overshooting approach with left
rudder led to reduced eng comp stall margin, contributing to left eng comp
stall. Accepted. CLSO and BLSO perceived MA left rudder input during WUOSX. See...it says "percieved", not "assumed" as you put it.
It also notes that there was a mechanical problem found that would increase the likely hood of a compressor stall by 26% in any phase of flight. Nope,...Stall MARGIN was increased by 26%, not quite the same thing as you are trying to imply... It was also found that her training was deficient in single engine wave-off training as well as other areas. I think you meant to say her training performance was deficient...read section in the MIR showing her CQ grades. Second, the report faulted her for not communicating the engine failure to her RIO. Result was that the RIO was not aware of the engine failure and could not pass along critical information to the pilot. And the REASON the RIO could not do so was a result of the pilot's error!!! The engine failed at 300' and 8-10 seconds before impact and she was task saturated. Again, this is generally something we tend to discourage in our pilots...Part of which was steering the aircraft away from the boat. (Thanks for inserting your personal supposition which is uncorroborated from any professional findings.) The other two critical areas were the late ejection (trying to not hit the ship and kill other sailors might do that) (supposition) and exceeding the max SE AOA, which happened 80' above the water just as they cleared the ship. Pilot error on waveoff technique
So to place blame on the crew was easy and assumed a lot, but it was not entirely truthful. Read between the lines if you read the MIR and just remember all of the circumstances that were involved. So now you believe, based on your vast personal knowledge and experience with Naval Mishap Investigations and personal knowledge of those involved, that the MIR is rigged......Your are a real piece of work...
For the record, it leaves a bitter tast in my mouth to have to regurgitate these matters on a fellow Naval Aviator, but your clear twisting of the events made my need to respond overwhelming...she f--ed up, ...it happens, .....may she R.I.P.....my prayers to her family. End.
